Author Topic: key position  (Read 2097 times)
Hussman
key position
« on: June 02, 2005, 02:08:02 AM »
can someone tellĀ  me what is soppose to happen in certain key positions, I had to bring my 76 750f in for a safety and the machanic failed it based on the fact that the bike doesn't start in P position, I don't think its suppose to, if someone could tell me what lights are suppose to come on in certain key positions i would greatly aprreciate it.
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: key position
« Reply #1 on: June 02, 2005, 02:11:13 AM »
This has come up before:
The key should have three positions:
1. OFF
2. IGN - bike should run, key cannot be withdrawn.
3. PARK - park lights work, key can be withdrawn.
At least, that's how it works here (UK) - other markets may be different.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Hussman
Re: key position
« Reply #2 on: June 02, 2005, 02:18:25 AM »
it's for a North american bike, parking lights is that the tail light and the headlamp or just the tail light and for the ignition setting is the tail light suppose to be on when the bike is not running in this position
Offline Paul
Re: key position
« Reply #3 on: June 02, 2005, 02:32:25 AM »
The "P" for park is only for when you need to nip into the shop for a minute in the dark.
It just keeps the rear light on so that the bike can be seen whilst parked.
If you are having issues with the mechanic as an extreme perhaps you could take a copy of the wiring diagram to show that ignition power is off and diverted only to the "Parking" light(s)
Paul.
It hurts to admit when you've made mistakes, But when the're big enough, the pain only lasts a second
Hussman
Re: key position
« Reply #4 on: June 02, 2005, 02:43:59 AM »
and what about the tail light when the key is in the ignition position should be on when the bike is not running or only when it is running?
    • TVAM
Re: key position
« Reply #5 on: June 02, 2005, 02:46:11 AM »
Just another thought.
In the User Manual it will tell you exactly what the key positions are for. Show that to the mechanic - he can't argue then.
If you don't have one, they are usually available on eBay or even downloadable from this site (?)
Take a look under your seat. That's where they are kept. Yours might still be there! (Mine was...)
SOHC4 Member #2393
2015 Tiger 800 XRT
    • TVAM
Re: key position
« Reply #6 on: June 02, 2005, 02:55:39 AM »
Don't know what the running light laws are like where you are.
In general:
"." (red dot) position on RH switch is lights off
"P" position on RH switch gives rear light and low wattage front "park" light
"H" position on RH switch gives low/high beam depending upon LH switch position
The lights should do whether the bike is running or not.
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline Gordon
  • 750K1, 550K2
Re: key position
« Reply #7 on: June 02, 2005, 03:31:02 AM »
It depends on whether your headlight has an on/off switch or not.  The rear running light should be on whenever the headlight is on.
    • TVAM
Re: key position
« Reply #8 on: June 03, 2005, 03:16:33 PM »
In general:
Here are some pics of the UK switchgear.
Note the ">PA" on the horn switch - flashes the headlight if you push to the right (earlier post but can't find it anymore)
SOHC4 Member #2393
2015 Tiger 800 XRT
Offline cb650
Re: key position
« Reply #9 on: June 03, 2005, 03:37:16 PM »
It should only have the tail lite on in keyed P position and not start.  Some of these guys can be real asses.
We dont have safety inspections but emissions check (cars only) and only one company can do them on 82 and newer.  Thats why all my cages are older.
                     Terry
