About February I noticed that the draft inducer bearings started to go out on my furnace. Sounded like it was mixing cement rather than blowing air. Since I'm so close to the end of the winter season I ignored it.
Steadily getting worse - used to be once in a long while, now it's every 4th or 5th time the furnace kicks in. I know it's the draft inducer because once the furnace stops heating air and only pushes it - the system sounds normally.
Easy to fix on my furnace - even a YouTube showing my exact model and it looks really simple (we've all heard that before
Only real hitch here is the price - that draft inducer is 400 bucks (OEM).
Since I have a good 6 months to play around with it, I'm curious if I can simply repair the unit or find an equivalent unit that's either 1) Quieter or 2) cheaper - but not a cheap Chinese knockoff.
The furnace is about 5 years old at most - don't recall exactly, Bryant 350AAV
