Hi All,
I recently started taking down my CB650Z prior to rebuilding it into a replica of the Paul Smart CB650 (What A Monster..)
All going to plan but I ran into an issue with one of the bolts that mount the engine in the frame and partially keep the small frames in place that the steps are mounted on.
This is a 12mm bolt, approx 25mm/10" long and runs from one side to the other of the bike, and at two spots goes through the rear/bottom part of the engine.
At the right side of the bike there is the nut to this bolt which came off easily and allowed me to remove the frame and steps. So far so good, .. when moving to the left side to do the same I found the bolt head wouldn't come loose.. It was only after going over the maintenance manual I found that it runs all the way through the engine's rear bottom. And I suspect it is there that it somehow corroded/fused together.. When I put a wrench on it, extend the lever a bit with a pipe and gently apply torque the only thing that happens is that the bolt twists.. so I stopped, way chance of snapping that bolt..
One thing I have been considering is hammering it out from the treaded side (direction to where bolts head is, so to the left) There should be no threading on the bolt other than the 1.5" on the end which is already exposed.. (going by the documentation)
Please see attached image of the part/location.. Is there anybody that has ran into this same issue, and do you have a fix/method to get it to come loose?
(..oh yeah, I figured it is stuck at the spot of the red dot as I can see the bolt flex along its length when applying force.)
Thanx in advance for any useful pointers and tips!
Monk
