Author Topic: Fork legs  (Read 699 times)
Offline robe0531
Fork legs
« on: March 05, 2017, 08:13:43 PM »
I tried to search for my answer but had no luck
I am thinking of doing the dual disc conversion on my 78 cb750. Can you just replace the fork leg with another left side leg and have everything line up
1978 cb750k
1968 Honda ca160
Re: Fork legs
« Reply #1 on: March 05, 2017, 08:21:47 PM »
Nope, your right leg should be fine..you will need to shim that side, and mod speedo drive if you want to run stock speedo.
Offline robe0531
Re: Fork legs
« Reply #2 on: March 05, 2017, 08:36:53 PM »
Perfect. Thanks for input and fast reply
Sent from my SM-G920P using Tapatalk
1978 cb750k
1968 Honda ca160
Re: Fork legs
« Reply #3 on: March 05, 2017, 10:03:33 PM »
The right has. Same mounts as left, (just reversed). or should have.
Re: Fork legs
« Reply #4 on: March 07, 2017, 11:29:56 AM »
Offline robe0531
Re: Fork legs
« Reply #5 on: March 07, 2017, 01:11:19 PM »
Thanks guys
1978 cb750k
1968 Honda ca160
