Author Topic: What oil after rebuild? cb750 /836  (Read 1027 times)
Offline la ca fe
« on: March 09, 2017, 09:43:14 AM »
What oil should my cb836 use after a bottom and top end rebuild?
It has a race cam in it as well, does this effect the oil type?
Thanks!
1976 cb750k
1975 cb750 f
1977 xs750
1978 xs400
Re: What oil after rebuild? cb750 /836
« Reply #1 on: March 09, 2017, 09:55:32 AM »
 Use a regular dino oil during break in for new rings etc..  Crap I betta get outta here     :o
Offline 700504
« Reply #2 on: March 09, 2017, 10:00:05 AM »
gn4
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
« Reply #3 on: March 09, 2017, 10:06:33 AM »
Too many opinions here on specific oils to run, but I will 2nd ekpents post.
regular 20w50 dino oil.  Not synthetic.  Change it often during break-in.
I went on mileage....50, 200, 500, 1000...
@1000mi I switched to my preferred oil.
Offline markreimer
« Reply #4 on: March 09, 2017, 10:41:28 AM »
Endless opinions. I used rotella 15-40 dino for break in. And then keep using if after. Still using it, in all my bikes for that matter.
« Reply #5 on: March 09, 2017, 11:00:35 AM »
I followed this last time and pistons looked much better than the slow break in I did back in the days.
http://www.mototuneusa.com/break_in_secrets.htm
I have had the entire engine apart, new pistons and rings...
10w-40 (mineral).
I have just ordered Motul 3000 2x4L 10w-40 and 2x4L  20w-50.
10w-40 to start with, change oil after 50km, then another 10w-40 for 1000km more. Then 20w-50...
Or I'll give my really modded engine something better, Red Line Motorcycle oil 20W-50 that I have on the shelf
Motul has semi synth 5100 and better synthetic 7100 too. I have not tested Motul yet.  I guess that 5100 can be OK too.
I'll try that one in my K2 that are still in pieces in the garage.
You guys in USA have a lot of lubrication to use!
