Support the site. Your contributions keep this site running.
If you don't want to modify the handlebar, you then have to modify the bar controls.I used a dremel and made the wiring "U" relief much larger. Then it could clamp down.Still punched a hole into the handlebar for the nub in the controls.
You have to remove that nub inside the controls, too. Or drill a hole for it. They stay clamped tight without it.
Much nicer job is to drill the holes. I use a step drill. measure from end of bar to holes. Transfer to new bar. Drill 3 overlapping holes then file smooth. Drill the pin hole. Tape ends of wires together. I use soapy water in a spray bottle for lubrication. Push and pull wires through. You'll be happier with a nice clean look
I didn't like how Honda had the wires going through the bars making it a pita to run the wires through them. My solution was to drill an appropriately sized hole in the bottom of the switch housing. I'm also running clipons and thought it wouldn't look good with the wires coming out of the end.
