The SOHC/4 World Tour is in under way.
Quote from: 1978CB750SS on March 12, 2017, 04:42:43 PMI checked "Bolt on" didn't see anything that would be a direct fit that wasn't 100 or more. except this vintage chopper thing that was available on ebay for a short time,had a circular mount for frame.. Yes, to me, this is a big bike. Thanks for the tips to getting it up there alone.My back is long gone.Can't lift like I used to. For years I used to pick up/ deliver furniture, safes,appliances, pool tables. No more.Back is toast. I think what I want is a factory replacement style 78 cb750F ss factory mount welded where it is supposed to be. Maybe someone had a junk 1978 CB750 SS (or identical) frame and can cut that area off for me, I could grind off the excess and weld it in place. I want it to look factory.One more hurdle in the quest for a nice ride.I do have a Harbor Freight welder and it would be fun to get it to look right and be right...im operated 2 times for discos colaps..and have one more vating..and cant lift anything either...but to set a cbx or 750 on senterstand..is only a matter of use your ovn vaight..to press the horn..dovn..it vill lift the bike,,and then you just need to pull it lightly backverd..its just magig how easy it vorks..the problem is if somone have hacked in the stand,,remover the horn..or bend it...then the vaight/arm mekanism is gone..my 500 t vas a hell to get up..and i sold it..thay bike is/vas as heavy as the cbx to move araund..and even slow as hell..put a small handel on by the rear damper or a rail araund the seat helps to pull the bike..and make moving it araund..its helm me a lot moving my bikesriding is not the problem..its the" still stand" pushing araund vho Hurts the bag..and ve dont vant to drop aur bikes..
If you are not planning on using stock K pipes, welding it on slightly ahead should not matter. Remember though that trying the actual77/78 sidestand will be too long, you will need a 69-76K type.
Here ya go, I took this off a '78k. PM me your address and I'll send it to you.For those who are watching, what would a fair price be for my time to dig this frame out of the attic and carefully cut the part off?And just for shts and giggles, here is the abandoned hardtail project I took it from... I started it when I was young and foolish. I'm too old to start riding a hardtail!
Canadian Noob / Saturday's Wrench CB350 had some type of bolt-on kickstand, if I remember correctly. Sent from my iPhone using Tapatalk
