Author Topic: 350F intake manifold  (Read 772 times)
Offline excelpowderwerks
« on: March 13, 2017, 06:35:30 AM »
Ordered new intake manifolds because the the old where rock hard, new ones are only slightly better. My question is there are two distinct manifolds two of each, does anyone know the order these go on in. I have tried six ways to Saturday and they don't seem to line up with the carbs. I have two 16212-333-030 with a small notch on the side and two 16213-333-030 without the notch .  Any help???  Thanks
Re: 350F intake manifold
« Reply #1 on: March 13, 2017, 08:04:54 AM »
I may have this sorted out . The two 16212-333-030 go on the outer cylinders and the 16213-333-030 are inboard. All part numbers on top or facing up.  Anyone??
« Reply #2 on: March 13, 2017, 02:54:14 PM »
Should be correct.  Inners are the same and outers are the same.
The edges facing/connecting to the carbs should all be flush with each other.
Hold a straightedge across them all to verify.
Offline chrisbc55
« Reply #3 on: March 21, 2017, 12:29:30 AM »
Mine had no.s on them.  1 or 4 on the outside ones, 2 or 3.on the inside...if I remember correctly. Place the no.  facing up so they read 1,2 ,3,4 according to cylinders
