Have you measured the crank journals with a micrometer?
http://s890.photobucket.com/user/edhaeuser/media/CB750/20130605_221452a_zpsc4afc7d6.jpg.htmlMy newer crank I installed have thicker journals than my old that ran OK with browns before.
I read comments from a experienced guy that my values were fine, good oil flow. 0.063-0.076 mm seems to be much.
I got around 0.050mm / 0.0020".
Max clearance according to the Honda manual is 0.046mm /0.0018".
Green shells in which corresponds well with the crank and stamped cases. They green shells have max 6000kms. Old crank is slightly slimmer.
"Case has letters BBBBB, all crank journals have same sizes, 35.980 - 35.985mm"
Measure your journals and you will have more facts. The plastigauge used might be of wrong type? It is made for current clearance area?
