Author Topic: Where to get braided SS brake lines made?  (Read 7116 times)
Offline Scott S
« on: March 15, 2017, 11:17:02 AM »
  Slingshot seems to have gone M.I.A. again. I have a hydraulics shop near me that can make them for cheap, but they look a little industrial compared to the clean lines Slingshot has/had. Plus, I kinda want black lines for a stealth look.
 Are there other places making lines that you trust? I'll need them for my 550 soon, but this is actually for mt VF500 and there are a LOT of lines; 3 front brake, one rear and two clutch. And there are some hangers that need to be on the line. I can send the old lines in to be matched.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Where to get braided SS brake lines made?
« Reply #1 on: March 15, 2017, 11:20:56 AM »
There are some good outfits on ebay that I remember using.
http://stores.ebay.com/rennsportautoparts/
I used this guy before I went with Slingshot. They do custom orders, or sets for bikes.
--Evan
1975 CB750K "Rhonda"
Offline Ericcb750
« Reply #2 on: March 15, 2017, 11:48:28 AM »
Hey Scott, I actually just re-built my braking system using a Black Stainless goodrich line from 4-1. It got rid of the pipe at the end (by the caliper and just mounts into two banjo fittings at the caliper and at the master.
I was going to go with Slingshot but like you said....M.I.A. I had a brand new Honda brake pipe and everything... Just be careful of the length needed, just in case. Hope that helped a little
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
Offline Scott S
« Reply #3 on: March 15, 2017, 11:59:47 AM »
 I need a place that can make up lines. The CB550 will have an R6 front end and 400F bars, so those won't be stock CB lengths.
 The VF500 are all stock length, but have some hangers and what not.
 I'll check with the place near me. They might not be exactly the color I want or what not, but they are pennies on the dollar compared to most places that make custom lines.
'71 CB500 K0
'81 Yamaha XS650
« Reply #4 on: March 15, 2017, 12:26:21 PM »
galferusa
spieglerusa
paragon performance
cyclebrakes
venhillusa
Offline edwardmorris
  • Youngish
« Reply #5 on: March 15, 2017, 12:45:49 PM »
Raymond Chan at Apex makes them for 750s, I got a set from him  http://www.rennsportautoparts.com/ call the toll free number or find him on facebook.
Offline Desert-SOHC
  • It's old
« Reply #6 on: March 15, 2017, 12:53:19 PM »
G and J Aircraft in Ontario, CA did mine.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: March 15, 2017, 01:04:53 PM »
You might have them made a tad longer than you need. I tried 400F bars on my 550 and didn't like it at all. Made my shoulders sore after 10 minutes of riding so I went to 32" low rise and all was better. FYI.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #8 on: March 15, 2017, 01:18:12 PM »
I like the 400F bars you sold to me,I removed the black plastic end cap pieces to narrow them just a tad.
I lean-over forward out of the wind on my bike when I ride and they do help,thanks.  ;)
  • Youngish
« Reply #9 on: March 15, 2017, 01:51:49 PM »
To clarify, he will ask you for specific lengths even if its a well known model like the 750, so I'm sure he can do the VFR ones if you provide the exact lengths and other info he'd need.
Offline evanphi
  • Apparently I'm an
« Reply #10 on: March 15, 2017, 02:43:33 PM »
I posted the ebay link for his place above, too.
--Evan
Online Stev-o
« Reply #11 on: March 15, 2017, 03:05:44 PM »
+1 Apex, Mo is this the same guy?
http://www.apexbrakes.com/custom.asp
He's in Canada but ships out of US rather quickly. I used him on my K3 last year when Slingshot was off.
  • Youngish
« Reply #12 on: March 15, 2017, 03:09:18 PM »
Yep, same guy.
Offline Scott S
« Reply #13 on: March 15, 2017, 05:00:23 PM »
 I've actually used Apex before, but there are some scary reviews on Google now about Apex failures.
'71 CB500 K0
'81 Yamaha XS650
Offline Garage_guy_chris
« Reply #14 on: March 15, 2017, 10:25:14 PM »
I used Z1's line system of pick lengths, pick ends assemble. I did two lines down to the calipers on my dual disc conversion and works perfectly.
https://www.z1enterprises.com/z1-categories/wheel-brake-tire/ss-hose.html
Offline DaveBarbier
« Reply #15 on: March 16, 2017, 05:24:18 AM »
I used Apex as well and Raymond is a really nice guy. Can you link to more bad reviews? The only one I can find is this one from 2010 and as you read the page it may have not been a brake line failure but the suspension pulling out the lines from the fittings (this was on a car at a track). If there's more evidence to lines failing I'll have to take a look at mine and consider new ones.
http://rennlist.com/forums/racing-and-drivers-education-forum/576388-warning-defective-brake-lines.html
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #16 on: March 16, 2017, 06:06:07 AM »
+1
I have used these on two different builds as well.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #17 on: March 16, 2017, 06:01:23 PM »
Just buy the fitting adaptors, and -3 line from Earls Supply or Summit, and make your own.
 This way will guarantee the lengths are right. Its not real hard, and you can always make a shorter line  out of a long one.
Offline Scott S
« Reply #18 on: March 17, 2017, 03:03:12 PM »
 Just found a set of Galfer lines for my R6 swap on the local Craigslist for only $50! Sweet! Brand New and in black, just like I wanted.
'71 CB500 K0
'81 Yamaha XS650
Offline riverfever
« Reply #19 on: March 18, 2017, 08:20:53 AM »
I forgot I needed a line because I've been so fixated on wiring but then remembered the other night. Shaun was great a few months ago about communicating with me. This is unfortunate.
Offline Tews19
  • I am no
« Reply #20 on: October 08, 2018, 07:02:57 AM »
Does anyone have the length and size we need for a 1970 750? Mine came with an extended one
1970 Honda CB750 survivor.
« Reply #21 on: October 08, 2018, 07:23:44 AM »
If you dont get any replies, use a piece of Cat5 or the existing line to guestimate...
Offline Bankerdanny
  • Endeavor to persevere
« Reply #22 on: October 08, 2018, 11:32:02 AM »
The braided lines I put on my 550F last summer came from Apex. I did the custom route to get the exact length I wanted. They fit perfectly.
Offline Tews19
  • I am no
« Reply #23 on: October 08, 2018, 01:41:16 PM »
I'll call them
Online Stev-o
« Reply #24 on: October 08, 2018, 02:13:36 PM »
I'll call them
Call?  I've just ordered from the website....
