Not the exact answer you are looking for. Hopefully close
Not DP295 cam, but a similar cam. It must be an aftermarket, regrind or...?
The cam has RC295 scratched on the side, under the bolt and washer. Numbers not that far from RC295/DP295
IN lift: 9,980 mm (0.0393") @ 0 lash 25/55 duration 260 @ 1mm lift (0.04") LC 105,00
EX: lift: 9,220mm (0.0363") 55,5/22 257,5 LC 106,75
Overlap 47
I timed cam with adjuster screw tightened until the dial indicator just started to move @ 0.
I have a DP315 cam, now in engine. Values for verification of Dynamans cam card and RC315 numbers vs my my timing.
(This is the later RC315 version)
DP315 Lift: 9,33/9,33 mm @ 0 lash 35/62 68/33 Dur 277/281 @ 0.040"lift LC 103,5/107,5 overlap 68
DP315 Lift: 8,95/9 mm @ 0,3mm running lash 28,5/56,5 60/26 Dur 265/266 @0.040"lift LC 104/107 overlap 54,5
DP315 cam numbers are more understandable for me at recommended lash of 0.3mm
