Ok, so, if you double a stock single piston caliper, for the 550 this is a 38mm piston, then his recommendation is to use a 14:1 to 12:1 ratio for single piston calipers like we have.  So, for a stock single single-piston caliper to get to that ballpark you need a 10 or 11mm caliper and for twin stock single-piston calipers you need it in the 14, 5/8, or 16mm range.
So, what does a twin 30mm single caliper need, non opposed design like the Honda calipers used in 80s on lots of bikes need?
Yes Brent, you are very much correct in stating this helps a great deal get you into brakes that work much better.  I am just trying to understand some of the other things that can affect this to get things in a better ball park.
With a single modern 4 pot (twin opposed) caliper you would use the 27:1 to 22:1 ratios suggested.
Do the radial designed MC have any different affect than the older design MCs?
Thanks!
I guess if you can afford to get rid of the stainless disc for a cast iron disc you would have far more effective brakes as well.  Too bad there are not any inexpensive sources for a bolt up disc for the 550s and early 750 bikes.
