I've recently rebuilt my 74 cb750 engine, as well as the oil pump with Elan's kit. The bike runs very nicely, probably better than ever since I bought it 6 years back.
I'm having a weird thing with the oil level in the tank though.
After I rebuilt the engine just before winter, I primed the pump, added the usual 3.5 litres of my favourite oil, verified I had oil flow and pressure, and started the bike up. I was able to run it maybe 100km before the snow fell, so I put it away.
This spring I was doing some other spring maintenance, fired the bike up and rode around the block a bit, then came back in for an oil change. I checked the dip stick and found it was almost dry.
![Shocked :o](http://forums.sohc4.net/Smileys/default/shocked.gif)
But my pressure gauge indicated I had proper pressure the whole time, so I didn't panic. It was only running a few minute anyway, and there WAS oil in there...
When I drained the oil, it seemed to have a bit less than 3.5L to my eye, but I didn't actually measure it. I put fresh oil/filter in, measured it accurately, went for a ride, shut the bike off and put it on the centre stand, then checked the oil - Bang on, we're all good.
Fast forward to today - I check the oil after a 10km ride and it's massively OVER filled. About an inch from the cap, and I've got oil spitting out the overflow tube that runs down by the swing arm. The whole ride I had good pressure on my gauge (right side of engine), so I know it's circulating as it should, but what's up with the fluctuating oil level in my tank?
Once again - oil pump was fully rebuilt with new seals/shaft seal/o-rings etc. Pressure is around 65psi at start-up, and slowly falls as it heats up, always maintains at least 10psi at idle. No leaks anywhere.
