She is a stock 76 750F with the exception of the new long-@$$ Jardine slip on muff. Carbs overhauled, though still I believe I need the top plates with the rubber grommet in the center for the slide rods (old round top). I have installed new manifolds on both sides of the carb a few years back. Three plugs are sooty, number two being the oddball and it looks fine. I have noticed number three doesn't run well at idle, and my compression reads 1-4: 130, 127, 125, 110. My plug wire cap on number three is in fact broken.
Also to note: When she acts up, I have this flat spot at low throttle. cracked it is fine, but after that and for about a 30 degree twist of the throttle engine seems to load up. When it runs okay the flat spot is still there, but much smaller. This flat spot makes navigating corners at speed very dangerous.
I ran an entire can (not at once) through her when I first got her out again. I have checked the screen inside the tank, and have a new inline after that. The tank vent is clear. Still need to go through and check all my electrical connections, though.
Thanks everyone for the help. She is a good old girl and forever has a place in my heart and my front yard. Sorry, but the 86 FWB de'Elegance has the garage.
