Author Topic: Modifications started  (Read 11079 times)
Re: Modifications started
« Reply #75 on: June 08, 2017, 09:32:23 AM »
But.... will it glow in the dark?  ;)
Offline PetesPonies
« Reply #76 on: June 08, 2017, 02:57:29 PM »
painted
Pete's Ponies
Mustang RUSToration & Performance
« Reply #77 on: June 08, 2017, 04:13:13 PM »
That green candy is so bright.  I think the best words to describe it are brilliant or radioactive!  These body pieces really pop against the frame and motor.
Offline PetesPonies
« Reply #78 on: June 08, 2017, 04:49:15 PM »
They do, and it will be even better out in the sun. I painted a Jeep once for a niece of mine. She went to the paint store with me to pick out the paint. The Jeep was black. She choose a three stage paint that used a black base, so it was an easy transition. The mid coat was crazy. It was all different colors, depending on the angle and the sun. I knew when she went through an intersection on a sunny day, she'd cause problems. I haven't seen another on the street with that paint since. However, it didn't take her long before she totaled it  :(  Like so many paints, camera and screen just don't do it justice. Let your imagination go when looking at this modest picture. My candy green isn't like this . .but I like it a lot.
Pete's Ponies
« Reply #79 on: June 08, 2017, 05:11:18 PM »
Whoah. That's a LOT to take in.  Taste the rainbow!  Maybe the other driver's were so distracted by the paint that they crashed into it.
Offline PetesPonies
« Reply #80 on: June 08, 2017, 06:13:39 PM »
Nope, it was her fault and was at night. The paint had nothing to do with it.
Pete's Ponies
Offline theDQG
« Reply #81 on: June 08, 2017, 07:10:51 PM »
'83 xv920
'76 xs650
cb750 k4 (2)
'81 R100RS
DQG = The Dumb Question Guy. I ask dumb questions all the time. Bike over ego.
Offline PetesPonies
« Reply #82 on: June 09, 2017, 08:37:57 AM »
Side covers . . .
Pete's Ponies
« Reply #83 on: June 09, 2017, 08:52:20 AM »
Looks great Pete.
Are you familiar with Penetrol? It's a non-automotive paint additive thing. It would probably work great on the airbox to make it look new again and darken it. I've used it on a number of plastic pieces to restore their appearance. Wipe it on/in and let it sit and absorb then wipe it off.
« Reply #84 on: June 09, 2017, 09:25:52 AM »
Good match on the candy.  It's not an easy thing to get it right when you paint the parts in separate sessions.
Offline PetesPonies
« Reply #85 on: June 09, 2017, 10:40:48 AM »
I have heard of that material, but have never owned any. I have other materials I use for things like that. Understand black, in photos like this seem to always look worse than in person. I also have not cleaned or detailed a thing since I purchased the bike. I started tearing  down almost immediately.
As for the candy match, well when I mixed up my candy concoction, I mixed enough to do all my parts. So then it's all up to the amount of coats to keep it looking right. Plus . . none of the pieces actually touch each other. I'm sure that helps  :)
Pete's Ponies
Offline BPellerine
« Reply #86 on: June 09, 2017, 05:32:13 PM »
very nice,the covers turned out great!bill
1978 CB 750K ard and webers
another anfob
Offline PetesPonies
« Reply #87 on: June 09, 2017, 09:54:59 PM »
Thanks. Time to finish the front fender and ride.
Pete's Ponies
Offline PetesPonies
« Reply #88 on: June 10, 2017, 09:11:03 PM »
Finally mounted the taillight and wired it. I also added an electronic strobe and LED taillight bulb. Pretty cool.
Pete's Ponies
Offline Can550
« Reply #89 on: June 10, 2017, 11:19:44 PM »
Sweet but sharp
Great work
Offline PetesPonies
« Reply #90 on: June 14, 2017, 05:03:47 PM »
Had three things left to do . . now it's two. I got the cap resealed and installed. I was able to install the new seal without taking the cap apart. Took about 10-15 minutes to get it in, but it's done. Th most difficult part was installing the latch. I went with a keyless latch and it was a little bugger  :)  But it's done. The cap looks better in person than the pic. Chrome just doesn't photograph well, or it just shows everything  :) I decided not to use the front fender I had for it, so I'm waiting on the fender I purchased to show up. The last item to finish is the rear turn signals which should be done tomorrow.
Pete's Ponies
« Reply #91 on: June 22, 2017, 09:39:16 PM »
Another trick that works well on black plastic is peanut oil.  Apply generous coat and let it warm up in tne sun and later wipe it down.  It does a fabulous job bringing the deep black back to black plastic pieces. Once wiped off it does not collect dirt/dust or transfer to other things.  Works quite well and is long lasting.
