Author Topic: CB500/550 electrical panel with combo reg/rec  (Read 638 times)
Offline Scott S
« on: April 08, 2017, 06:32:06 PM »
 Show me how you mounted a combination regulator/rectifier on a 500/550 electrical panel. Looking for a neat way to mount it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline calj737
  • I refuse...
Re: CB500/550 electrical panel with combo reg/rec
« Reply #1 on: April 09, 2017, 03:48:24 AM »
On the back side between the panel and the battery box.
« Reply #2 on: April 09, 2017, 07:24:35 AM »
This one obviously doesn't use the airbox so I mounted it here so it hopefully sees a little cooling airflow. It's an Oregon part.
Offline Scott S
« Reply #3 on: April 09, 2017, 10:28:55 AM »
 Are you using the stock plenum? Is there room? It seems like it would hit the air box, but I don't have a stock bike to look at right now.
'71 CB500 K0
'81 Yamaha XS650
