Start with an idle plug chop to ensure your IMS (idle mixture screws) setting is correct .
ride the bike with current plugs. get the engine hot.
park the bike and put in a set of NEW plugs, and start the bike.
Idle, under a fan, 4-5 minutes. no blipping of the throttle.
pull the plugs and post us a picture to see.
Alright well I'm already bracing myself for a shake of the head because these spark plugs don't look like anything happened to the but, as requested, here are my plug chop pictures. I still have the plugs incase you want different perspectives.
Now a little background... I rode about 6-7 city miles home before doing this, so I think the engine was sufficiently hot. A note on that ride though... When I rode into work earlier, the engine ran pretty good, though it hesitated slightly while climbing the bridge. Not he way back, however, when I started it up it was not smooth at all and was making a lot of subtle popping sounds. After warming in up for 4-5 minutes, I started on my way and when I started laying into it it lost about half it's power - a bit unnerving as I was about to pop onto a small stretch of highway and I was struggling to push 50 mph. After about 10-15 minutes, the issue subsided and I was running pretty well.
In my very limited knowledge, I thought this meant maybe the plugs were fouled and the sparks weren't happening. But when I pulled the plugs with about 120 miles on them, three were pretty neutral in color and one was white.
Anyway onto the plug chop...disclaimer is that I live on the third floor of an apartment building in the city with no garage or place to plug a fan. There was about a 5 mph breeze and it's in the high 50s outside so I hope that's not too distant from a fan blowing.
I took out the plugs within five minutes of shutting off the hot bike (burning my hands repeatedly) and put in the new plugs. I started up the bike at 10:43 and ran it until 10:48 pm, at which time I shut it off. Then I pulled out the new plugs (burning my hands a few more times) and replaced them with the original plugs.
Without further ado, here are the pictures (the number on the plug box corresponds to the cylinder):
EDIT: I do realize these pictures are rather poor but I'm dead in the water til daylight. The flash just obscures everything and it's otherwise too dark. I hope to post better ones tomorrow.
