Author Topic: Concrete Solid Color Stain/Sealant  (Read 1899 times)
« on: April 12, 2017, 10:42:17 AM »
I had an additional 400sf added to my existing backyard patio slab yesterday, and now am planning for staining/sealing it.
Any of you have experience with H&C Solid Color Sealer or any other concrete colorants/sealants?  Thoughts?
I'm looking for something to darken the color of the concrete and be waterproof.
-Rob
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Concrete Solid Color Stain/Sealant
« Reply #1 on: April 12, 2017, 11:15:22 AM »
The best way to color concrete is to mix it in as it is being batched. I can't help you with any post-set sealants.
Offline Ridem32
« Reply #2 on: April 12, 2017, 11:29:01 AM »
I have never used any concrete sealants.  But I worked in a Nissan dealership shop had it on our floors and it's great! Cleans up easy and want stain with oil etc. If it's prep rite I think it just paints on
Offline Lostboy Steve
« Reply #3 on: April 12, 2017, 12:32:30 PM »
There is nothing more beautiful than a polished concrete floor. No good outside though. I have had very mixed experiences with concrete treatments. Non of them were spectacular.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #4 on: April 12, 2017, 12:47:29 PM »
Thanks gents.  Just looking for something to protect and add a little color.
Offline J-Rod10
« Reply #5 on: April 12, 2017, 01:47:00 PM »
Have them epoxy coated.
Offline Ridem32
« Reply #6 on: April 12, 2017, 01:56:22 PM »
Check with homedepot or Lowes
Offline turkey4me
  • The closer you are the less you can see!
« Reply #7 on: April 13, 2017, 05:26:16 AM »
I made concrete counter tops years ago and stained it with Kemiko concrete stain.  Not sure what I used for a sealer.  Concrete Network is a helpful site.
Offline MoMo
  • Ride like you're invisible
« Reply #8 on: April 13, 2017, 05:56:56 AM »
check the rustoleum epoxy coverings available at Home Depot.  Some are a tad pricey but they are decent quality stain/sealers at a somewhat reasonable price compared to the high end products.  Mick(retro rocket) from what I remember used to do this for a living...Larry
« Reply #9 on: April 13, 2017, 07:47:09 AM »
Thanks for the leads, gents.  I'll follow them and see what I can find.  8)
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #10 on: April 16, 2017, 12:07:57 PM »
You must seal outside concrete. The stuff they put down today is so bad that it will flake when it soaks up water and the temps get close to freezing. You end up with a surface full of pock marks.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
Offline 74cb750
« Reply #11 on: April 17, 2017, 05:21:36 AM »
Too true. Found this out the hard way. Will be sealing it this spring as the flakeing has already started.
What did you seal the concrete with? Did you use something like this?
Quikrete Concrete Resurfacer The Home Depot
Laugh at least once a day.
Life  $ucks, then you die.
« Reply #12 on: April 17, 2017, 08:17:58 AM »
After this patio cures for 30+ days, I think i'll move forward with this product....I'll post some before n after pictures once done.
https://www.sherwin-williams.com/homeowners/products/h-c-colortop-solvent-based-solid-color-concrete-sealer
Offline J-Rod10
« Reply #13 on: April 17, 2017, 09:39:13 AM »
If it's started flaking, you'll probably want to have it ground before putting epoxy on it.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #14 on: April 18, 2017, 07:04:28 AM »
Concrete flakes because of an improper application (floating too much water up) and an improper cure (outside in, not inside out). It has nothing to do with "today's concrete", only today's Concrete tradespeople.
All poured in place concrete is 3,000psi when cured. So, if you want a proper install, perform a slump check at your site before you accept the pour. Then hold the contractor (or yourself) responsible for proper cure.
 ??? ??? I wish I could say I learned something today.... :-\
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
