Author Topic: She finally lives! Project 466  (Read 958 times)
Offline Jore
« on: April 17, 2017, 10:33:35 PM »
Hey guys, it's been a while since I've posted anything, but today I got my bike complete, all the wiring is doing, all the mechanical parts are done, she starts, brakes and runs!
It's been god knows how long since I started this project which was a mild 400 resto that turned into a 466 and a whole lot custom everything.
Anyhow, after a full day of finishing the wiring, I took the bike out for a shakedown, rode it about 3 miles, it was awesome so light and nimble, like ridding a bike, but as with everything  I still need to fine tune it, here are it's issues:
-The idle is terribly high, even with the idle screw backed out completely.
- I'm using one of those ebay 12 buck tachometers and it reads extremely high, something like 8k at idle, my idle is high but nowhere near 8k, I'll hook up the old one and see it's true speed.
-I'm pretty sure the timing is off, might have to shim the plate or something, since statically it can be timed to the t mark, but once it's running and I shine the timing light on it, it's nowhere near any of the marks.
EDIT:
- I forgot to mention that once the bike is up to temp, I'm having trouble finding neutral, the bike's running castrol gtx 15w-40 with the lucas zinc additive (zddp or zdpp).
-Also once up to temp power seems to go down a bit, not an awful lot but I could go WOT and the bike wouldn't rev that much higher.
And the pretty much sums up what I have to do with the bike.
« Last Edit: April 17, 2017, 10:39:08 PM by Jore »
1975 CB400F owner
-Having a vintage motorcycle is like having a moody girlfriend.
My 466 build: http://forums.sohc4.net/index.php/topic,146494.0.html
Re: She finally lives! Project 466
« Reply #1 on: April 18, 2017, 03:47:09 AM »
 I noticed you said you had it timed to the "T"mark. If like a 750 the t stands for tappets when those are adjusted and there may or should be an "F" mark on the plate for 'fire' to set the timing.
Offline DaveBarbier
« Reply #2 on: April 18, 2017, 05:10:27 AM »
Thought the T stood for Top dead center...but yeah, it has to be set to the F mark.
Your tach could be for an engine that's not a wasted spark system so it would register double the RPM. Still, 4k rpm is too high obviously. You might have to re-bench sync at a lower slide height. If I remember correctly I bench sync with a 3/16" drill bit.
I used a Castrol oil and added zddp and I always had a hard time finding neutral when hot. I switched to Spectro Golden 4 semi synthetic 20w 50 and I can find neutral all day long.
Offline innovativems
    • Innovative MotoSports
« Reply #3 on: April 18, 2017, 06:20:00 AM »
Are your points worn?  If you are out of adjustment slots to get it on point, then could be you need new points.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #4 on: April 18, 2017, 06:47:16 AM »
WTH Jore!....you're holding out on us.  ::)
Post a picture!  8)
Offline Jore
« Reply #5 on: April 18, 2017, 08:08:36 AM »
Sorry I meant the F mark. And yes my points are probably worn and/or warped, I actually had to file a bit the slot on 2-3 to get a bitmore adjustment on them, I did order a new set, that allegedly will get here in about a week.
As for pictures I only have this one from instagram: https://www.instagram.com/p/BSfFxzrgRFe/?taken-by=osuna.jore
I'll post some more decent ones later today after I'm back from work.
Thanks for the replies!
1975 CB400F owner
Offline Jore
« Reply #6 on: April 18, 2017, 08:13:32 AM »
BTW the slides where all benched with a needle as a reference, but know that I think about it, I did shorten the throttle cable, could it be that it's binding or maybe it's too short and that causes the throttle to open? I'll have to disconnect the cable and see what happens.
I found a post here that gave instructions for hooking up a tach similar to mine so I went with those and also another one I found on youtube, I might have to play around with it still.
1975 CB400F owner
