Author Topic: Stuck engine?  (Read 883 times)
Offline JimZ
Stuck engine?
« on: April 29, 2017, 03:51:45 PM »
Hey everybody. 1975 cb550. Last spring I tore down the engine. New piston rings, cylinder, rocker cover, and all associated gaskets and o rings, etc. Rode great all summer. Today I changed the oil, drained and put in fresh gas, took the fully charged battery off the trickle charger and connected it back to the bike, and put air in the tires. Should fire up and go, right? Wrong.
It started up with one push on the electric start, but it was making some serious pinging noise from inside the engine. I gave it a little throttle and it turned off. Now it seems to be seized. The kick won't kick. Hitting the electric start I can here the starter spin but the engine just hits a wall and won't budge. It rolls in neutral and it rolls in first gear. It won't shift any higher than first gear. The crankshaft bolt only turns about 20 degrees in either direction.
So. What the hell? Cam chain tensioner no good? Cam chain came off sprocket some how? What was the loud pinging noise? Valves were fine last time I rode it. Stuck pistons? Just changed oil so it wasn't lubricated enough when I started it? Or, something I haven't gotten into at all yet, transmission problem? Really disappointed. After all that work last year I thought I was just gonna charge the battery and go. Any help is greatly appreciated.
Offline eigenvector
Re: Stuck engine?
« Reply #1 on: April 29, 2017, 04:17:09 PM »
Drop the pan and look upside.
Also - take off the cam cover and look inside.  Camchain does have a nasty tendency to fall off - seized my engine before.
Best bet - take off the pan and look.  I'm guessing it's cam chain - but you might have dropped a valve.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline Ridem32
Re: Stuck engine?
« Reply #2 on: April 29, 2017, 04:36:48 PM »
One or more of the cylinders could be full of gas due to a sticking float. Pull all the spark plugs and see if it will turn over. Good luck
Offline uksparky
  • Track days
Re: Stuck engine?
« Reply #3 on: April 29, 2017, 05:46:39 PM »
Was the bike sitting since last year, then you changed the oil few days ago/gas etc...if yes the pistons are dry.....if it was not started in that time period you should have pulled the spark plugs  and 4oz light oil poured into each cylinder, with top end done last year all should be good
Present bike 1982 900C Custom
