Author Topic: '74 CB550 carb rebuild  (Read 3777 times)
Offline BallAquatics
  • Wrenching & Riding
    • My Life with Motorbikes
« on: May 07, 2017, 10:35:32 AM »
My bike was put away badly almost 30 years ago.  Needless to say, the carbs are wrecked.  I thought maybe a good clean and I would be good to go, but when I started working on them it became appearant that wasn't going to be the case.
One of the slow jets broke off in the carb, but I think I got the piece out and cleared the passage.  Other than the rubber being shot, everything else looks pretty good.
I'm thinking about getting this kit from 4into1 ( http://4into1.com/carburetor-repair-kits-complete-set-honda-cb550k-1974-1976/ ).
This doesn't seem like it's going to be a big deal, but is that just wishful thinking on my part?  Any advise or comments would be most welcome.
Dennis
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: '74 CB550 carb rebuild
« Reply #1 on: May 07, 2017, 10:42:04 AM »
Its an okay kit.
Oem are still available.
Keihin brass bits are available too.
Ultrasonic cleaners rule.
And keep everything well sorted on the bench.  There are a few bb's and brass studs involved should you be completely dismantling the carb rack.  I like tackle boxes or hardware containers for this sort of work.
« Reply #2 on: May 07, 2017, 11:19:20 AM »
Thanks for all the tips BomberMann!  Do you have a favorite place to get your parts?
Do NOT swap the stock brass for aftermarket brass; it's a can of worms that won't settle in your stomach. The stock brass can almost always be recovered and is better and more consistent.
The o-rings and gaskets are perfectly useable from these kits and you're better off simply buying that type of kit.
Thanks calj737!  That was my original thinking, but when I twisted off the slow jet...  Other than the broken slow jet my brass looks good.  Where does one find just gasket & rubber rebuild kits?
Dennis
  • Holy Cow! I'm a
« Reply #3 on: May 07, 2017, 11:36:24 AM »
www.hondabike.com
My local honda dealership offers discount pricing on web ordered oem parts.
Otherwise, swap meets and ebay.
« Reply #4 on: May 07, 2017, 12:06:21 PM »
Thanks again BomberMann650.  Not sure how far out I'll have to go to find a dealer around here.....  Our local shop closed up years ago.
Dennis
Offline flatlander
« Reply #5 on: May 07, 2017, 12:27:11 PM »
you can get original keihin jets here: https://www.jetsrus.com/
« Reply #6 on: May 07, 2017, 01:04:25 PM »
Thanks flatlander!
Dennis
Offline Scott S
« Reply #7 on: May 07, 2017, 01:11:48 PM »
 Original Keihin brass, new O-rings, shaped float bowl gaskets from 4into1. And see if you can find someone to ultrasonically clean them. Don't forget to pull the emulsion tubes!
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #8 on: May 12, 2017, 12:54:41 PM »
Put the rebuilt carbs back on today with new intake rubber and it fired right up.
Man, what a relief!!!  I was hoping this wouldn't turn out to be a major ordeal.
If I thought the carbs were bad, you should see what's growing in the fuel tank.  Original plan was to give it a good wash and go, but when I opened it up.....
Well that's tomorrows job.  Give it a good wash and fill it up with evapo-rust and see what happens.
Thanks again for all the help guys!
Dennis
  • I'm back
« Reply #9 on: May 12, 2017, 12:59:11 PM »
Why not start with washing the worst out with a litre of diesel.
« Reply #10 on: May 12, 2017, 01:02:20 PM »
I guess I could do that.  I thought I'd just turn it upside down and wash it out with the garden hose.  It's got some serious stuff growing inside.
Dennis
« Reply #11 on: May 12, 2017, 02:42:20 PM »
Does feeding clean carbs with dirty fuel sound like a recipe for success?
If you are trying to remove tank rust, I was pretty happy with the electrolysis method for removing rust WITHOUT removing good parent metal.
Acids remove both.
« Last Edit: May 12, 2017, 02:46:49 PM by TwoTired »
  • Holy Cow! I'm a
« Reply #12 on: May 12, 2017, 02:45:09 PM »
Was it Berrymans Chem Dip that left carb bodies nice and shiny?
« Reply #13 on: May 13, 2017, 04:22:50 AM »
After finding some of the thread on here, I'm just going to dry out the tank and then rattle around some drywall screws before give it the evapo-rust treatment.
Dennis
