Author Topic: This is how plug wires should look on 750.  (Read 1632 times)
« on: May 07, 2017, 05:08:24 PM »
 This I had on my chopper, cleanest way to run the plug wires. I built a bracket and ran the coils under the carbs.
 Now i finally have the shaved cam cover, carbs, and the magneto... Dont think I will mill the fins that far back..
 Looks like a Ness frame..  Meydos will be drooling over that pic..
« Last Edit: May 07, 2017, 05:12:31 PM by 754 »
Re: This is how plug wires should look on 750.
« Reply #1 on: May 07, 2017, 09:16:42 PM »
 I'm doing that with my ARD mag.
« Reply #2 on: May 07, 2017, 09:26:51 PM »
I will to with a mag.. One problem though.. 8mm might be awful tight or need a bit of filing.
 And if you got big liners , they may tighten it up.
 I really hope my old red Thundervolts are long enough, if not I have a roll of yellows 7mm steel core silicone wire. Soon as I get ends, I can make some up for folks.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #3 on: May 08, 2017, 07:06:06 PM »
i believe that was a dave perewitz bike.  super cool ;D
« Last Edit: May 08, 2017, 07:14:10 PM by Medyo Bastos »
Offline Maximum Carnage
« Reply #4 on: May 08, 2017, 10:32:40 PM »
Now the throttle cable and return, do those too!!
Charlie
1971 CB750
1964 CA77 Dream (sidelined)
Offline BLAC
  • An espresso is a
« Reply #5 on: May 09, 2017, 10:04:55 AM »
"The Diddler"  :o  That thing sounds like rolling probable cause.
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
