Author Topic: coil on plug, with a twist.. would it work?  (Read 1031 times)
Offline oddballmotorsports
« on: May 13, 2017, 12:37:11 PM »
so, I need new coils for my build..  since I'm weird,  I have decided to try something.  coil on plug..  now I can already hear y'all saying, but there's 4 cylinders,  and two coils,  well, the answer (I hope) lies in a dodge hemi (5.7) coil.  its a "wasted spark" setup where the coil boot goes to the spark plug, and then a wire runs to the companion plug..  In a dodge its two plugs firing on the same cylinder but the design is the same. and the primary coil is 3 ohms..  so, yeah thats it.  think it will work?
Offline dusterdude
Re: coil on plug, with a twist.. would it work?
« Reply #1 on: May 13, 2017, 04:03:24 PM »
Yes
Sent from my R1 HD using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline drumstyx
« Reply #2 on: May 13, 2017, 04:12:03 PM »
Huh? Why do we need to get so fancy? Over on the Concours forums, people run coilovers by just splitting the coil supply wires and hooking them up to 1-4 and 2-3.
« Reply #3 on: May 15, 2017, 03:26:25 AM »
that's an option too..  however if one were to run 4 individual coils,  with 2 in parallel in each circuit, they would have to be 6 ohm coils as when you run resistors in parallel, their resistance splits..  I'm sure there's 6 ohm coils out there..  what coil packs are they running?    the reason I thought a waste spark COP would be better as its cheaper than buying 4 coils..   but then one has to find weird spark plug wires as the second coil tower has a funky connector..  allthough it could be easily modified to accept a "regular" wire..
Offline przjohn
« Reply #4 on: May 15, 2017, 05:38:53 AM »
You don't say what bike you are working on but the SOHC 4s that I have worked on are already wasted spark ignition. There are 2 coils going to 4 plugs, why not just replace the existing coils with like coils if they are bad?
Offline PlungerWaffle
« Reply #5 on: May 15, 2017, 08:04:30 AM »
Give it a shot! What could possibly go wrong?
« Reply #6 on: July 02, 2017, 07:47:29 PM »
a shot I took,  and it worked..  Looks a little bulky,  but I think I am going to make some air scoops that cover the coil plate which will also direct air over the motor, or possibly run a different tank thats a little wider..  not sure yet..  the only thing I'm worried about is these coils are designed for 6k rpm at limited bursts.  so 10k is pushing it a ton.. I have a feeling their going to fail quick..  their cheap enough to where I can replace them as needed, but I would rather not..
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #7 on: July 02, 2017, 08:04:35 PM »
If this is a 750 you will want to put some 1 ohm 10 or 20 watt resistors inline with the positive feed to each coil. 3 ohms allows too much amperage for the ignition switch and kill switch and will eventually fry them.
