Author Topic: 1978 CB550... I tried to keep it stock, I failed.  (Read 22834 times)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Re: 1978 CB550... I tried to keep it stock, I failed.
« Reply #75 on: August 07, 2017, 07:37:42 pm »
Looks amazing!
I have a motorcycle problem.
Offline riverfever
« Reply #76 on: August 08, 2017, 07:27:53 pm »
Damn that paint looks good!
Offline BLAC
  • An espresso is a
« Reply #77 on: August 28, 2017, 12:54:25 pm »
Soooooooo. I decided to just completely rebuild the bike from the frame up  ::)
I stripped it down and sent the frame and swing arm to a sandblaster:
I hung them from a wire for a makeshift paint booth:
My girlfriend walked out and asked where my motorcycle was... she rolled her eyes at my now TWO projects..
About 4 coats of Eastwood Chassis Black:
This is far as I got on the engine tear down.  I am just going to clean, paint and install a 650 cam:
Cylinder is black VHT, Planning on block sanding the fins.
Of course I had to test fit some of the pretty parts =)
« Last Edit: August 28, 2017, 12:56:46 pm by BLAC »
If you can't fix it with a hammer, it's an electrical problem... If it's an electrical problem, it's Cal's problem.
*2005 Yamaha R6 (sold)
*2014 Ducati Streetfighter 848 (sold)
*2014 BMW S1000RR (sold)
*2010 Ducati Streetfighter S
*1978 CB550 Restomod Build
*1974 CB550 Monoshock build
http://forums.sohc4.net/index.php/topic,154614.0.html
« Reply #78 on: August 28, 2017, 02:07:01 pm »
Keeping it stock is a battle I am losing.
« Reply #79 on: August 28, 2017, 02:07:21 pm »
Looking good, B.
Offline BLAC
  • An espresso is a
« Reply #80 on: August 28, 2017, 03:02:52 pm »
Thanks, Don!
Does anyone have a bare 77-78 CB550 seat pan they are willing to get rid of? I need to chop one up for a shorter seat
Offline calj737
  • I refuse...
« Reply #81 on: August 28, 2017, 05:04:04 pm »
Just make one from aluminum you lazy, Bastage!  ::)
« Reply #82 on: August 28, 2017, 05:16:33 pm »
Are you aiming to keep the stock functionality of the hinges and just shorten the overall seat?  So much for stock!!  :o
Offline BLAC
  • An espresso is a
« Reply #83 on: August 29, 2017, 12:01:34 pm »
Your overestimate of my skillset is flattering  :P
Offline Camrector
« Reply #84 on: August 29, 2017, 12:09:48 pm »
Looking so good!
« Reply #85 on: August 29, 2017, 12:26:16 pm »
I want to be adopted by his girlfriend's grandfather -- or at least get to use his sweet garage!
Offline calj737
  • I refuse...
« Reply #86 on: August 29, 2017, 12:54:00 pm »
Take a 1/8" sheet of aluminum. Trace the hoop/rails. Cut with a jig saw. Propane torch to heat it, bend it to fit curvature. Dress edges with grinder and flap disk or files. Locate hinges. Done yet????  ::)
Offline BLAC
  • An espresso is a
« Reply #87 on: August 29, 2017, 01:21:54 pm »
Aaaaaand I'm headed to the "Wanted" section to create a post... ;D
Offline Restoration Fan
  • My wife will never call me
« Reply #88 on: August 30, 2017, 08:59:20 am »
cal is an absolute master of the understatement, isn't he?  :D
Offline calj737
  • I refuse...
« Reply #89 on: August 30, 2017, 10:16:36 am »
I remain unafraid to attempt anything, whether I have expertise or not. Cowardice is not welcome in my home  :P
Offline BLAC
  • An espresso is a
« Reply #90 on: August 30, 2017, 10:52:38 am »
Im not afraid to try, but I know someone who made tens of thousands of them already... Honda  :P
I also want it to be steel so I can weld onto it. I need to incorporate a brake light into the seat somehow  :o
Offline calj737
  • I refuse...
« Reply #91 on: August 30, 2017, 03:22:36 pm »
Pssst! Brake light mount from aluminum. Weld aluminum to aluminum.  ;)
Offline BLAC
  • An espresso is a
« Reply #92 on: September 01, 2017, 11:31:54 am »
Might be a stupid question, but I can not find any reference to which engine mounting points are the grounds (unpainted).
Is it just the back two that make direct contact with the frame?   ???
« Last Edit: September 01, 2017, 01:27:44 pm by BLAC »
Offline calj737
  • I refuse...
« Reply #93 on: September 01, 2017, 03:57:12 pm »
Right rear upper motor hangar bolt and engine bracket. The NEG cable grounds between them and the frame.
Offline BLAC
  • An espresso is a
« Reply #94 on: September 01, 2017, 05:23:36 pm »
Is there a downside to having more than just that one ground point?
For some reason I thought it was the bottom rear two as well, so I have all three of hose unpainted...
« Last Edit: September 01, 2017, 05:28:35 pm by BLAC »
Offline calj737
  • I refuse...
« Reply #95 on: September 01, 2017, 06:50:22 pm »
The battery only has 1 NEG terminal. It only needs 1 ground point.
Offline BLAC
  • An espresso is a
« Reply #96 on: September 18, 2017, 11:51:02 am »
I got the whole motor reassembled and put in the 650 cam.. but then I realized I forgot to put in the two hollow dowels that go between the cylinder and the head... The step by step I was looking at didnt use them and I didnt notice them until I was cleaning up my bench.
son of a BETCH.
ok... so I used a brand new OEM base gasket and head gasket, with permatex copper spray in both. I also used hondabond on the new pucks, so it is sealed up nice.  My question is...
Do I need to run those dowels? If not necesary should I just leave it as is since everything is sprayed and torqued?  If I do have to run them, can I reuse my brand new head gasket?
this is a bummer  :-\
Offline NobleHops
« Reply #97 on: September 18, 2017, 12:16:41 pm »
son of a BETCH.
Bryan, I don't have a qualified answer on the dowel pins so I won't opine, but I will say, 'been there, done that' in similar fashion, and whether or not they speak up, I bet a dozen ore more guys that read this are saying it too. Re your head gasket, if it is MLS I personally think the answer is no on reuse, and yes if it is copper. Paper gasket, unknown, but if it isn't damaged when you pop the top off, I am going to GUESS that reuse is fine.
N.
Offline BLAC
  • An espresso is a
« Reply #98 on: September 18, 2017, 12:20:54 pm »
son of a BETCH.
N.
Thanks!I actually was watching the soco videos and actually found him on this forum and someone else said "hey I built my motor watching your video but I dont think you used the alignment dowels between the cylinder and the head" he responded with "im not sure what you are referring to' then the thread died  ::)
 I used the stock OEM gasket that is the waxy/graphite looking thing. Im not sure what it is made from. its not the aftermarket MLS though
Offline calj737
  • I refuse...
« Reply #99 on: September 18, 2017, 12:31:57 pm »
Best answered by Mike R (in my opinion)
