Author Topic: Dyna S on Ebay - Dumb Idea?  (Read 12061 times)
Re: Dyna S on Ebay - Dumb Idea?
« Reply #75 on: May 18, 2017, 03:35:01 AM »
Years ago I got around for months with two 6 volt dolphin lantern batteries when my battery died
Are Dolphin batteries rechargeable John? And I have to ask, why didn't you just install another battery mate? ;D
Offline Ridem32
« Reply #76 on: May 18, 2017, 04:39:32 AM »
Had a 1953 panhead. It was a 12 volt system with points. Only used one battery 6 volts with polarity reversed. Bike ran fine. Had to unhook the generator. But it got me home. About 20 miles
Offline cb400f/20yo/semi-broke.
« Reply #77 on: May 18, 2017, 05:18:00 AM »
My dyna s1 just failed. would only go back if money was not a problem for me
« Reply #78 on: May 18, 2017, 06:14:54 AM »
I am pretty sure my buddy rode his 59 pan, from Vancouver to here, on a lantern battery... About 280 miles..
Offline Ridem32
« Reply #79 on: May 18, 2017, 08:46:39 AM »
But you do have to reverse the battery cables.  I was using one battery not 2
Offline PetesPonies
« Reply #80 on: May 18, 2017, 08:53:06 AM »
Again people don't understand.Making claims when you don't understand something is bad for everyone. It promotes misinformation. Cars are 12V as well as motorcycles, sure. But the voltage is lowered when it goes to the ignition system. Voltage is easily changed in a series circuit with resistance. Resistance acts as a voltage divider and depending on the resistance chosen, you can have any voltage output desired up to the full voltage. This is what happens and why a 12-14V vehicle with points, has only 8-9V in the primary circuit of the ignition. This is where I get a bit uneasy and quick when I see misinformation passed along. I'm not sure why anyone here doubts the facts, except that they just don't know.
Pete's Ponies
Mustang RUSToration & Performance
Offline Lostboy Steve
« Reply #81 on: May 18, 2017, 09:15:25 AM »
Who gives a #$%* how they work? They work. There is NOTHING wrong with a properly adjusted points system. I run them in a daily driven corvair that I beat the ever-loving piss out of.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #82 on: May 18, 2017, 09:22:53 AM »
Motorcycles are 6V and 12 V.
Offline PetesPonies
« Reply #83 on: May 18, 2017, 10:29:04 AM »
Well just because you don't care doesn't mean the world doesn't have to care? Be real. They work, just not as well. If you don't give a crap, good for you. And if you don't want to learn, good for you too. But some people like to learn and understand.
Pete's Ponies
Offline PetesPonies
« Reply #84 on: May 18, 2017, 10:30:44 AM »
Of course. But the point ( punny huh? ) is 12V doesn't mean 12V is going through the primary ignition circuit with a points system, because it doesn't.
Pete's Ponies
« Reply #85 on: May 18, 2017, 12:01:39 PM »
Driving down the road system voltage is about 13 V.  ...What with the alternator/ regulator operating.
Bike's wiring distribution from battery to coil, if maintained, loses about 0.5 V at most.  (It can be less in un-maintained bikes.)  So, 12.5V is presented to the coil hot side primary.
Proper points present no resistance at full contact.  It's a metal to metal contact, very near zero ohms, effectively presenting a low resistance battery neg return to the coil opposite the battery supply connection to the other coil primary lead (neg).
I can't find on any SOHC4 wire diagram where there is any other resistance present in the coil primary circuit.
Admittedly, there are battery load conditions at startup, that can lower power distribution voltage.  But, that seems a corner case, certainly for consideration, but not a normal run time case.
I'm not seeing a reason for a 3-4 volt loss that's not presented to the coil primary?
Forgive my abject stupidity.
« Reply #86 on: May 18, 2017, 01:11:47 PM »
TT, I think PetesPonies is referring to certain automotive systems (i.e. Chevy's and Mopar at least, I don't know about Ford) that provide full voltage to the coil only when the engine is cranking, but cut voltage to around 9 volts after the engine is running via a resistance wire(Chevy) or a ballast resistor(Mopar) to prolong breaker point life...this is totallly irrelevant in regards to SOHC4 bikes, as they do not use such circuitry.
« Reply #87 on: May 18, 2017, 01:46:07 PM »
Gold wings have a drop resistor, too, as well as many cars.  But, the thread is in the SOHC4 Bikes forum, so I assumed...
The ballast resistor is not just for breaker point life.  Many use 6V coils for extra spark at start up, which simply overheat and produce melty bits when operated consistently on 13-14 volts.
More... off topic...
I've had a Mark ten CD ignition (Radio Shack kit I assembled) in my 72 Ford truck, since the 80s.  Same set of points since then, too.
Fully loaded on the way to AZ did 95 MPH while teasing a later model Corvette on I40.  No premeditation, it just happened.  ;D
I don't think he appreciated the original patina on my truck.  Just a guess.
There's a bypass switch on the unit, in case of EMP.  ;)
But, the unit did fail one day, 10 or 20 years ago.  Had to use that bypass switch.   Problem was a transistor switch inside.  I replaced that and it still works to this day.
I should probably check the points setting next tune up...
« Reply #88 on: May 18, 2017, 02:58:34 PM »
Wow, you drive a Corvair Steve? Well in that case your ignition is the least of your problems! ;D
Offline jonda500
« Reply #89 on: May 18, 2017, 05:33:51 PM »
Carbon zinc dry cells aren't meant to be rechargeable- but I have found they will accept a small amount of charge, and didn't explode like they're meant to when I've done it.
I couldn't afford a new battery at the time, 2 cheap lantern batteries at the time only cost me $4.70  :)
John
A starter clutch thread:
« Reply #90 on: May 18, 2017, 05:56:06 PM »
Oh no, I know exactly how, I also know how the others work, I'm just saying this is a dumb argument. I would love to see a dyno chart showing an improvement. Significant, not 2% because that's just a waste anyway.
Sent from my LG-V520 using Tapatalk
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #91 on: May 18, 2017, 05:58:52 PM »
I love it. Probably one of the safer cars ive owned. Has a gasoline heater too!
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
« Reply #92 on: May 18, 2017, 06:04:16 PM »
Geez, if a Corvair ("Unsafe at any speed") is one of your safer cars Steve, what the hell were you driving before it? A Fred Flinstone car? ;D
« Reply #93 on: May 18, 2017, 06:09:46 PM »
Stop bugging him about his Pinto and Fiero....
 You just envious , as they wouldnt sell them to your bunch...
« Reply #94 on: May 18, 2017, 06:20:20 PM »
That's BS Frank, I'm the proud owner of a Ford Exploder, way more upmarket than a Corvair, but just as dangerous! ;D
Online scottly
« Reply #95 on: May 18, 2017, 07:13:20 PM »
Ford does the same thing; the starter solenoid has a terminal marked "I" that bypasses the resistance when the starter is operating. I have a Ford Motorcraft coil that came with the 289 I originally installed in my Cobra kit-car that is marked "12V use external resistor". A V-8 coil must produce 4 sparks every revolution of the crank, while our coils only produce 1 each. In order to due this, the car coil has a much lower primary resistance, like 1.5 ohms compared to 5 ohms, which greatly increases the current through the points. With a 1.5 ohm resistor, the running current is cut in half, to allow longer point life. BTW, I traded the "kit-car from hell" for the dyno. ;D
Offline PetesPonies
« Reply #96 on: May 18, 2017, 08:13:43 PM »
Most all points systems provide full voltage to the primary system during starting. But as soon as the starter is disengaged, the system reverts back to 8-9V.
Pete's Ponies
Online scottly
« Reply #97 on: May 18, 2017, 08:15:58 PM »
Not on our bikes.
Offline PetesPonies
« Reply #98 on: May 18, 2017, 08:28:33 PM »
Ah . . but you have something else . .you have twin coils.They have their own resistance . You put two in series and you effectively cut the power in half to each primary circuit. So even though the operating voltage may be 13-14V, each primary circuit is seeing only 6-7V.
Pete's Ponies
Online scottly
« Reply #99 on: May 18, 2017, 08:46:16 PM »
The coils on our bikes are not in series...
