Author Topic: Best way to strip paint off of side panels?  (Read 1867 times)
Offline jabbadeznuts
« on: December 15, 2006, 05:37:54 PM »
I'm about to repaint my tank and side panels. I was thinking that sandblasting would be the best way get paint off of the side panels. Any thoughts?
'75 CB550
'82 Suzuki GN125 - glad to be rid of that thing.
Offline ElCheapo
    • Anubis Cycle
Re: Best way to strip paint off of side panels?
« Reply #1 on: December 15, 2006, 06:53:19 PM »
NO SAND BLASTING
NO AIR CRAFT STRIPPER
Just good old fashoined elbow grease and some wet 400 grit sand paper.
As far as I have found there is no easy way around these.
You dont have to remove all of it, just most of it.
Contact me for affordable rotor drilling services at $55 each rotor. Same day service on CB750/CB500/CB550 rotors. Next day on everything else.
Offline grumburg
  • 74550, 76400F, 72 750 67S90, 68CL90, 65 s65 66 x6
« Reply #2 on: December 16, 2006, 06:41:54 AM »
Start with 220 grit wet/dry paper. Use lots of water and just keep after it. Allow lots of time and have plenty of beer. Bare plastic is an ugly yellow/cream. When all the paint is off, sand with 400 wet, wash with water, paint with sandable primer. Re-sand with 600, fill any knicks with spot putty. spray a VERY light coat of black spray paint and carefully resand with 600 to block sand any waves. One more coat of primer and I guarantee that will look like a million bucks.
Fonda Honda
Offline jtb
  • An unlikely
« Reply #3 on: December 16, 2006, 07:01:38 PM »
What he said! ;D
1977 CB750F
1985 V65 Sabre
Offline kghost
« Reply #4 on: December 16, 2006, 07:07:32 PM »
Yup paint stripper on plastic makes goo....
If you want to save some elbow grease and the paint is good but horribly faded....
Sand it rough then epoxy prime the panel before you paint.
Generally the factory paint had excellent adhesion and scuffing it followed by the epoxy seals it off nicely.
Stranger in a strange land
« Reply #5 on: December 16, 2006, 11:58:26 PM »
NO SAND BLASTING
I didn't know if sand blasting would eat the plastic up but there's no way in hell I'd be using aircraft stripper. I'd like to put back on painted side panels, not painted balls of goo.
'75 CB550
Offline mkramer1121
« Reply #6 on: December 17, 2006, 08:48:27 AM »
I got a fiberglass tank from ebay yesterday and started to tear into it before I saw this thread.  Its rattlecan painted yellow with some decals on it.  What I did before I gave up was use gas, as there was already some runs, and brake fluid, cause you figure you'll spill that on a tank at some point (at least I will in my clutzy ways).  Well, long story short, nothing came off, not even the decals.  Hosing it off after the fact to get all the caustic chemicals off, I again tried to get the decals off.  And they peeled off without any issue, without anything but water....figures...I'll let the paint shop handle priming the tank and sidecovers from this point on...
Offline medic09
« Reply #7 on: December 17, 2006, 09:47:58 AM »
actually, the petroleum products may well have loosened the decals.
a Honda mechanic in ABQ told my to just apply a heat gun or my wife's hair dryer to decals to get them loosened.
Mordechai
'78 CB750K
'07 aprilia Caponord
Santa Fe, NM
Offline Rsnip988
« Reply #8 on: December 17, 2006, 06:43:44 PM »
Soak it in HPLC Grade Acetone
haha that would dissolve the covers completely,
the wet sanding with the 400 should work as Tom said,
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline Jeff.Saunders
  • Obsessed by Old Motorcycles
« Reply #9 on: December 18, 2006, 03:41:01 PM »
There are some paint removers specifically designed for plastic.  Go to a paint supply place and talk to them.  I'm not sure of the name, but I know the place that painted my turbo bike used a PPG paint remover on the plastic parts.
Offline RatBikeRandy
  • Yes I Can
« Reply #10 on: December 30, 2006, 05:34:15 AM »
WD-40 or equivalent works good on decals as well.
