Author Topic: PCV Smoke  (Read 921 times)
Offline kac3177
PCV Smoke
« on: May 17, 2017, 11:57:43 AM »
How much smoke is normal coming out of pvc tube? Freshly bored cb750 bored out to 836. Plugs look normal... 80 miles on engine
kac3177
Offline 700504
Re: PCV Smoke
« Reply #1 on: May 17, 2017, 12:22:00 PM »
White smoke of blue smoke? If you run it real hot in stop and go situations, then it will pump a bit of whiteness out at idle and more when you wick the throttle. If it's blue smoke then you have combustion gases going past the pistons into the crankcase.
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
Offline kac3177
Re: PCV Smoke
« Reply #2 on: May 17, 2017, 12:25:47 PM »
White smoke. 20 miles to town, sat down and ate, stop and go around town after and 20 miles back
kac3177
Offline 700504
Re: PCV Smoke
« Reply #3 on: May 17, 2017, 12:30:49 PM »
Sounds normal, just crank case gases, if it's just open to atmosphere it can be quite noticeable in colder temps. If I'm not mistaken, the weight and type of oil can affect it slightly. Also the smell of normal gases is very distinct, if it smells like gasoline or burning oil; then you have more of a problem.
« Last Edit: May 17, 2017, 12:32:22 PM by 700504 »
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
Re: PCV Smoke
« Reply #4 on: May 17, 2017, 01:42:31 PM »
It magically goes away if you put a K8 re-breather on it  ;)
Offline 700504
Re: PCV Smoke
« Reply #5 on: May 17, 2017, 02:02:13 PM »
Lol, out of sight out of mind. Just like how the cure for the mysterious cb750 clutch rattle is a pair of ear plugs.
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
Re: PCV Smoke
« Reply #6 on: May 17, 2017, 02:15:37 PM »
;D or earbuds  8)
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: PCV Smoke
« Reply #7 on: May 19, 2017, 08:01:10 AM »
;D or earbuds  8)
and Mastodon!  ;D
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Re: PCV Smoke
« Reply #8 on: May 19, 2017, 10:32:35 AM »
;D or earbuds
and Mastodon!  ;D
Emperor of Sand is awesome!  8)
