Author Topic: If I can do this, you can certainly fix a crack  (Read 5255 times)
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
Re: If I can do this, you can certainly fix a crack
« Reply #25 on: May 22, 2017, 11:31:40 AM »
This is a common topic in the Goldwing forums. There's a lot of plastic on Wings, so repairing it eventually becomes a necessity.
http://goldwingdocs.com/forum/viewtopic.php?f=5&t=35675
The second post in the thread gives a how-to on making an ABS "slurry" out of ABS filings and ABS cement, and using that to repair the damage using a similar method as Pete. Scroll down to see examples of the repair technique as it is used on a fairing.
Thanks....hope you washed your hands(pinky finger),after doing a repair... :P :P :P :P
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline PetesPonies
« Reply #26 on: May 22, 2017, 11:39:44 AM »
When I taught, I used o put some MEK on my hand for the students to watch. It evaporated right before their eyes. Not much evaporates any faster  :)
Pete's Ponies
Mustang RUSToration & Performance
Offline PetesPonies
« Reply #27 on: June 07, 2017, 08:08:54 AM »
Here is where I am with the side covers now. They have been primed with epoxy. I will give these a couple days to cure well  and then block sand the epoxy. The epoxy I use sands well and I use it for blocking many times. After hat, the covers should be ready for paint.
Pete's Ponies
« Reply #28 on: June 07, 2017, 01:22:39 PM »
I sure hope you wore gloves when doing that trick. MEK is extremely harmful to your liver and is absorbed quite rapidly through the skin and into your bloodstream. Even the "new, watered down" stuff demands care when using.
YIKES! Lung protection, TOO!!
Offline Restoration Fan
  • My wife will never call me
« Reply #29 on: June 07, 2017, 02:12:58 PM »
Fantastic repair job on the side covers, Pete!  Well done and thank you for posting this because it encourages others of us to fix them as well.
Offline PetesPonies
« Reply #30 on: June 07, 2017, 03:22:05 PM »
First, no respiratory protection specifically needed for dropping a dot of MEK here and there on an acrylic piece that is being cemented. The health issues with MEK are associated with high levels, not an infrequent occurrence.
Thanks restoration fan, appreciated.
Pete's Ponies
« Reply #31 on: June 07, 2017, 05:23:05 PM »
Great repair job, Pete.
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #32 on: June 14, 2017, 04:42:18 PM »
Just wanted to say this method of plastic repair worked great on my Goldwing parts.  The stitching it back together with the solder iron was great.
Offline PetesPonies
« Reply #33 on: June 14, 2017, 04:56:30 PM »
I first starting doing it with Mustang consoles, long ago. The tricky part with a console is that it has a camera finish on the outside. You can weld the back, no problem, as long as you don't burn through. But to get rid of the break line on the front means some welding must take place. After the melting is done, I use the tip of the iron to simulate the camera finish. I wouldn't say it is entirely invisible, but I have done it well enough you wouldn't notice  it unless you specifically looked for it.
Pete's Ponies
