Anybody know the volume of oil an SOHC4 normally pumps?
For a CB 650 it's 21,3-26,3 liter/minute @ 3000 rpm (source: Haynes) That's about a gallon (US) every 10 seconds.
That seems a high value, doesn't it? Is that a free flow spec or one with an input to output pressure differential?
A pump that has no resistance to flow will allow more volume to pass than one that does. Obvious extremes are an open outlet and a blocked one. With variations in between.
Another variable would be the viscosity of the fluid traversed through the pump or the circulation path.
Anyway, what I am trying to get a feel for, is the volume of oil that is pumped through an SOHC4 engine, which is not the same as the volume of oil the pump is capable of producing, (when outside of the system it is intended to operate within).
If we know the volume and the heat transfer resistance, can't calculate the heat removal characteristics? I don't have the formula in hand yet.
