Author Topic: Oil Cooler Thread  (Read 179091 times)
Re: Oil cooler lines...
« Reply #800 on: January 16, 2009, 03:51:40 PM »
 Nothing I know either. Can you cut off the cooler barb ends and drill/tap for A/N fittings?
Offline HavocTurbo
  • Angry little bastard of an
  • Can you tell?
« Reply #801 on: January 16, 2009, 03:53:52 PM »
Bah you beat me to it...
Depending on the brand of cooler that shouldn't be a problem. We do it on sleds all the time.
'48 HD Panhead - Exxon Valdez
'78 CB550K - Fokker CB.3
'78 Honda CB750K - Mavrik
09 XL883L - No Name
Offline Steve F
« Reply #802 on: January 17, 2009, 06:47:24 AM »
Well, I don't know.  It's a Lockhart cooler, and looks like it's medium-duty tubing coming out the side, and I don't see any way of modifying this to a threaded fitting of any knid.  Maybe I'll try to design something of my own.  :-\
Offline voxonda
« Reply #803 on: January 17, 2009, 06:53:23 AM »
I use this setup, DOHC cooler and my own adaptor and adapted fittings.
Offline Steve F
« Reply #804 on: January 17, 2009, 08:26:50 AM »
Does anyone have technical drawings which include dimensions of these "AN" fittings?  I'd need info on the physical design of these things so I could work on designing something to suit.  A link to a website or something like that would be helpful.  TIA!
Steve F.
Offline Steve F
« Reply #805 on: January 20, 2009, 04:39:08 AM »
Steve F.
Bump...anyone?
Offline pddpimp
« Reply #806 on: January 20, 2009, 03:32:28 PM »
AN fittings are fittings from Aeroquip, Earls, ect. They have a 37deg flare with straight threads, which is aircraft spec. A standard pluming style flare is 45deg. You can find AN fittings at any performance automotive site, like Jegs or Summit Racing.
When the majority of the United States population get to be 70 years old, they will finally realize what is really important. And by then it'll be too late.
-'77 CB750 Cafe/Muscle bike (early clone)
Soon to have a hopped up 836cc *sold*
-'75 CB750 with a little bit of character
Offline nokrome
earls oil cooler pics?
« Reply #807 on: February 02, 2009, 12:20:55 PM »
anybody have any pics of one of earls (or one of similar design) oil coolers installed on their bike, im trying to get a visual of what they actually look like when installed.............thanks
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Re: earls oil cooler pics?
« Reply #808 on: February 02, 2009, 02:56:42 PM »
Here you go.
Offline nokrome
« Reply #809 on: February 02, 2009, 04:13:14 PM »
thanks MRieck, i was hoping you post on this thread, i read your post on these coolers from sometime in 05. i am considering the "narrow" version also, the "wide" version seems like it would stick out the sides way to far,
             are those AN6 lines? what type of adapter plate are you using? thermostat?
        thanks again
« Reply #810 on: February 02, 2009, 04:36:11 PM »
I'm a dumb ass, there was one on e-bay recently that I messed up & missed out on.  >:(
Offline nokrome
« Reply #811 on: February 02, 2009, 04:44:30 PM »
there are a lot of oil coolers on ebay that look like earls and are a lot cheaper, anybody know about the quality?
« Reply #812 on: February 03, 2009, 07:24:32 PM »
 pics you asked for. Setrab units are good quality too.
« Reply #813 on: February 03, 2009, 07:25:57 PM »
Yes....I'm running -6
Offline nokrome
« Reply #814 on: February 04, 2009, 08:50:58 AM »
if the stock oil lines are 1/2" id (approx an-10) do the an-6 lines create a restriction in the system? or is there a bypass somewhere?
    any thoughts on the quality of those ebay coolers?
Offline lordmoonpie
    • Moonpie
« Reply #815 on: February 04, 2009, 12:00:49 PM »
I think from memory my lines are an-8....you caqn get the whole kit at www.meadspeed.co.uk under cr750 parts...
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
« Reply #816 on: February 04, 2009, 02:12:14 PM »
I have never seen those CX units. I didn't want to much oil going to the cooler especially with my set up. The CR set up would certianly benefit from larger lines.
Offline voxonda
« Reply #817 on: February 04, 2009, 02:17:59 PM »
Hi Mike,
How large is your by-pass, presume you have drilled the adaptor?  I have a 5 m/m (7/32")hole drilled in my adaptor as a by-pass
« Last Edit: February 04, 2009, 02:29:30 PM by voxonda »
Offline nokrome
« Reply #818 on: February 04, 2009, 04:16:48 PM »
               thats interesting, how do you determine what size hole you need?.........any pics?
                     if you dont drill your adapter plate does that mean your total oil volume will be flowing through the cooler?
Offline voxonda
« Reply #819 on: February 04, 2009, 11:21:05 PM »
Imo it will, all the oil that normally runs through the filter will first run through the cooler. By drilling a by-pass hole a certain amount will run through the filter without being cooled.
Offline dusterdude
« Reply #820 on: February 05, 2009, 11:11:35 AM »
1/2 inch line is -8
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline snowfighter2
  • I really like Motorcycles, I guess that makes me an
oil cooler on return line to tank?
« Reply #821 on: February 21, 2009, 07:13:28 AM »
Has anyone ever tried to plumb an oil cooler into the return line from the engine to the oil tank? How about into the oil line from the oil tank to the engine? Anybody know of the benefits? I know space will be an issue, I'm just trying to see if it would be worth it, other than being different.
Andrew
That which does not kill you, will give you some awesome scabs, which turn into some cool scars!
1975 CB750K5
1985 GS 450E
1981 CB650 Custom
Re: oil cooler on return line to tank?
« Reply #822 on: February 21, 2009, 11:54:14 AM »
Like this?
http://www5.ocn.ne.jp/~sbmr0201/
Scroll down to third picture. Then click on it for more closeups of the plumbing.
many people here have done it. I hope they pipe up as i'd like them to review the idea as well. Others I've seen take the hoses up over the top of the engine into a cooler with the spigots on top.
« Last Edit: February 21, 2009, 11:59:43 AM by MCRider »
Offline City Boy
« Reply #823 on: February 21, 2009, 05:24:28 PM »
Hi there.You do not want to tie in the feed line from tank to engine to your cooler.This is a gravity feed line and will not function as intended.   Rock On
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline nokrome
oil cooler thermostat question
« Reply #824 on: April 21, 2009, 07:50:06 PM »
i am aware of the ongoing debate concerning the use of oil coolers, however i would like to know from those of you who choose to run them whether or not you also run a thermostat, the reason you do or dont and if you do what temp is it set for
                                                         thanks
