Author Topic: JB Weld and powder coating..  (Read 10706 times)
Offline Johnny340
« on: May 25, 2017, 01:56:00 PM »
I have this GSXR top triple clamp that I'm using on my CB750 and I want to have a bung on the bottom side to attach the gauge bracket  to.  I tried welding it and it turned out horrible and cold welded.  Same with a professional Tig. (crazy 'metal') So it's in position on the underside of the clamp which I plan to powdercoat black and wondered if JB weld was able to handle 400° in the oven or should I powdercoat it first then JB weld it in place over the powdercoat?
1975 CB750F0 Super Sport
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
Offline slikwilli420
  • Master of Disaster
Re: JB Weld and powder coating..
« Reply #1 on: May 25, 2017, 02:01:03 PM »
Powderman will be along here I'm sure, but I have been told that as long as you are using the original JB weld formula (not the quick set stuff) then it will be fine.
On the other hand, the fact someone wasn't able to weld that properly is a little disturbing since this is average cast aluminum and should be easily weldable.
Offline Lostboy Steve
« Reply #2 on: May 25, 2017, 02:15:40 PM »
Yes the original jb works. Labmetal is better though.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline innovativems
    • Innovative MotoSports
« Reply #3 on: May 25, 2017, 02:27:56 PM »
I've had good results with jb weld
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Johnny340
« Reply #4 on: May 25, 2017, 02:35:29 PM »
So the original JB Weld and Lab Metal has worked as in, you powdercoated on top of it and baked it at 400°?
I looked them up and apparently JBweld is good up to 550° and regular LabMetal 350° plus onetime exposures to 425ºF for no longer than 20 minutes, after they are fully cured.  I'm thinking JBWeld first, shape if required, then powdercoat, is the way to go.  Thank you for the replies.
« Last Edit: May 25, 2017, 02:47:03 PM by Johnny340 »
1972 CB750K2
1981 CB650
1974 T-500
2003 GSXR750
2006 YZ250
« Reply #5 on: May 25, 2017, 03:21:04 PM »
I use it as a filler on a swingarm and it worked fine when I had my powdercoat do it. Not sure what temp they bake it at.  I think 400
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #6 on: May 25, 2017, 07:47:43 PM »
No. I personally have not. I have used jb weld for aluminum repairs under powder and baked at 400. I have been told by professional powdercoaters that labmetal is better and that yes it is used prior to coating and baked at 400 degrees.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline PetesPonies
« Reply #7 on: May 26, 2017, 10:23:29 AM »
There isn't anything that can't be TIG welded.
Pete's Ponies
Mustang RUSToration & Performance
Offline Dracon
  • Wannabe Old Timer...
« Reply #8 on: May 26, 2017, 11:56:10 AM »
I've read that powder coating over JB Weld in very small areas is OK, but what about larger areas? I was thinking about smoothing out the transitions of where the welds meet the frame before having it powder coated. Even though it's not thick, with being a longer section would it still powdercoat OK?
Thanks
Offline PetesPonies
« Reply #9 on: May 26, 2017, 04:28:02 PM »
As an ex teacher who taught welding, I disagree. If you can make a rod of the metal to be weld, you can weld it. I melted down zinc based metals to make rods to fix the "potmetal" pieces.
Pete's Ponies
« Reply #10 on: May 26, 2017, 05:59:06 PM »
Thanks
I don't know, that's asking for trouble later. I would much rather braze those areas and grind smooth.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline PetesPonies
« Reply #11 on: May 26, 2017, 06:24:46 PM »
I wouldn't braze either. That is asking for problems down the road. Flux used in brazing leaches out and causes paint problems. If you want a smooth frame, use polyester filler.
Pete's Ponies
« Reply #12 on: May 26, 2017, 07:04:44 PM »
Polyester filler under powdercoat?
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline PetesPonies
« Reply #13 on: May 27, 2017, 06:07:53 AM »
No, no under powder coat, forgot about that. I would paint the frame with urethane. They hold up great, no need for powder coating.
Pete's Ponies
« Reply #14 on: May 27, 2017, 06:32:40 AM »
There are some fillers designed for under powdercoat.  One downfall of using jb weld as a filler is its very hard to sand.  If you want to fill the welds I also say fill it and then paint it.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Dracon
« Reply #15 on: May 27, 2017, 01:39:12 PM »
Thanks for the suggestions and information!
So as a self proclaimed noob, I was under the impression that powercoating the frame was the "best" way to get a durable/worry free frame. Though I have been reading that touch-up is difficult if something chips. What are your thoughts? Does the ease of touching up a painted frame make it a better solution for a bike that will be ridden often?
I'll admit, saving the money on PC'ing the frame, swingarm, forks, foot pegs, etc. is appealing...
Offline PetesPonies
« Reply #16 on: May 27, 2017, 03:17:20 PM »
A good paint job will hold up fine. Urethane is the material to specify, not enamel or acrylic enamel. Have the frame primed with epoxy, followed by the urethane. You re welcome to ask me anything about it, whether you want to do it or have it done.
Pete's Ponies
