Author Topic: When compressed air ain't enough..  (Read 9566 times)
Online Stev-o
Re: When compressed air ain't enough..
« Reply #75 on: May 30, 2017, 08:54:57 PM »
I like the compressed air removal method, a little excitement for a dull day!
« Reply #76 on: May 30, 2017, 08:59:28 PM »
Lessons learned thus far:
1. A stock 14mm master cylinder is capable of producing well in excess of 300 PSI, whether filled with water or brake fluid.
2. A grease gun can produce even greater pressures, and in the case of rear MCs, may be the only method that will allow the piston to be forced out, due to the much higher viscosity of the grease when compared to brake fluid or water; the passage to the reservoir allows thin fluids to bleed off pressure faster than the MC lever can be pulled. (Hopefully Lloyd won't read anything sexual into that. ;))
« Reply #77 on: May 31, 2017, 12:24:13 AM »
Actually, I'm just happy there are people fixing their own brakes, whatever method they are enamored with using.
« Reply #78 on: May 31, 2017, 01:36:22 AM »
Me too Steve, but then I thought about just hooking up my 5000 psi pressure washer and (just like JFK) thought, "Why the fcuk not?" all that pressure, and no messy grease or dangerous brake fluid to worry about............ ;D
Offline City Boy
« Reply #79 on: June 05, 2017, 03:04:46 PM »
Terry that's the best idea yet.Remove stuck piston and clean parts in one operation !!!
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
« Reply #80 on: June 05, 2017, 03:16:53 PM »
Will the 5000 pSi turn off as fast as the grease gun?
 If not you may wear it
I think a grease gun video should be made..  All 15 seconds of the operation start to finish, except cleaning it up... That may explain it better than three pages..
« Reply #81 on: June 05, 2017, 03:50:04 PM »
Yep, 15 seconds to unstick the piston, then the rest of the day to clean up the grease........ I'll stick with my shiny new pressure washer, 5000 psi will pop that piston out and clean everything afterwards! ;D
« Reply #82 on: June 05, 2017, 05:43:48 PM »
FTFY Terry..yeah I would rather spend 20 minutes saving the paint on a nearby vehicle, wiping the ceiling, my hair , my clothes,the wall and bench...... Because there is no way I am going to handle a piston size blob of grease, not spend only 1 to 4 minutes cleaning up grease....
 Because I am the MAN..I do it my way..
I totally understand..yep... If here is brake fluid still in there..it comes out in one lump by tipping over the refuse tin..
,but hey I understand...
« Reply #83 on: June 05, 2017, 05:49:11 PM »
Ha ha, while your stand up is weak, it appears that you understand humour Frank, so that's a good start....... ;D
