Author Topic: Marissa's 1972 CB500  (Read 108277 times)
Online HondaMan
Re: Marissa's 1972 CB500
« Reply #475 on: August 02, 2019, 09:40:07 PM »
That's a good place for crud to find its way into the tank...
What mainjets does it have? The #100 is as big as the 550 can take, usually it is more like #95, #98...although, this kind of fouling seems to be coming in the low-RPM range, which is the product of the idle pilot jets, their emulsifiers, and the air screw.
« Reply #476 on: August 03, 2019, 10:52:00 PM »
Where is the rest of the gas cap, should be a flat plate with rubber seal, and a round knob in the middle ?
Offline DaveBarbier
« Reply #477 on: August 07, 2019, 05:23:00 AM »
Do you know where you’re rich? WOT, half throttle, etc.?
« Reply #478 on: August 10, 2019, 02:50:15 PM »
Marissa how is the bike? School going OK?  Life treating you OK?
David
Offline Marissa
« Reply #479 on: August 14, 2019, 04:32:04 PM »
Life is good! I have been busy with the last few weeks before going back to school. I'm waiting on new spark plugs, float bowl gaskets, and Keyster float valves in the mail. I am going to take the carbs back apart all over again and clean the fuel hose and t fittings. And I think I'm just going to replace the float valves while I'm at it. I am getting tired of putting like 10 minutes of ride time in and then having them not close so I'm taking all the steps necessary to replace and clean what I could.
Sediment got in the tank somehow while it was airing out during those days of curing. I just realized if I had a small shop vac fitting I probably could pour the gas out and get ride of the grit. But I don't so we are going about this the hard way.
For temporary use, I have two filters on the fuel lines to make sure whatever dust is there does not go into the carbs. I'm hoping by my third fill up I can take them off and run it.
One of the carb bodies has threads that stripped out for the float bowls... I didn't realize I set the Allen key on the same bolt and of course I found out when I turned it half a turn and it fell out... So I need to retap it and find an M4 helicoil, because apparently that's an uncommon size. For now I fixed it with a nut and a longer bolt.
Once the new spark plugs are in, I'm going to start with just idling the bike, inspecting the plugs, and seeing if they are good enough to move onto 1/4 throttle. So on and so forth. I ordered two sets so I'm hoping I can get it pretty good with them.
I took a trip to Pontiac, Michigan with my boyfriend in his 68 Biscayne to check out Roadkill Nights and explore the area. We met up with a forum member who's got a killer garage set up with 2 CB350 fours, a Candy Garnet Brown CB500, a CB750, an H1 Kawasaki Triple, and a Bridgestone.
We found a CB550 at Borg Warner, too.
A 750 at M1 Concourse
1984 Nissan 300zx - sold
2016 Ford Fiesta ST - daily
1972 Honda CB500 - infinite work in progress
Instagram- marissasimos
Offline DaveBarbier
« Reply #480 on: August 15, 2019, 04:45:01 AM »
Nice bikes and space that member has!
Glad to see you’re moving forward. ONE thing that’s important, though. For plug chops you can’t work your way up from idle, 1/4, 1/2...etc. you need to work backwards. Every change effects the circuits before it. You can start with idle just to get the IMS dialed in so it idles nice and you get good plug color, but then go to WOT and work back and be prepared to fiddle with the IMS again.
« Reply #481 on: August 19, 2019, 08:21:10 AM »
Happy Birthday Marissa!
« Reply #482 on: August 19, 2019, 10:08:27 AM »
David
Offline Marissa
« Reply #483 on: August 30, 2019, 04:52:22 PM »
Thanks guys!
Can anyone tell me if these bikes need a little throttle at first considering they don't have accelerator pumps? I have been trying to trace this issue and in doing so I've gotten no where so far, then I came to the realization it could be just like old cars where you need to press the pedal at first to start it. And if such is the case then I have no start issue after all.
Online HondaMan
« Reply #484 on: August 30, 2019, 05:03:52 PM »
Thanks guys!
Oh, yeah...I think the modern computer-controlled cars (and bikes with EFI) have lulled many folks into misunderstanding that these bikes are all-manual, stick-shift, you-are-the-choke, don't-jerk-the-twister-too-fast models.  Which was how all of them used to be, in the 1970s! :D
Offline Scott S
« Reply #485 on: August 30, 2019, 06:23:48 PM »
 The old "manual choke", as in.... hold the throttle slightly open with your hand until it warms up enough to idle on its own.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Marissa
« Reply #486 on: August 30, 2019, 06:43:10 PM »
Oh thank goodness. I wasn't sure what to think, my boyfriends GS doesn't have an "off" for his fuel valve, and he also may have an accelerator pump (his is a 78 GS). So I was sitting here knowing he doesn't have to throttle his bike to start, assuming there must be an issue with mine since I have to. But then I realized his is later, and I remembered how cars needed throttle. So what a relief this is.
Here's what's going on now. The bike actually looks to be running lean now. Never thought I'd see this day.
To be honest, since I had to give it throttle to start, I assumed that was going to skew my idle readings so I took it around the block like 5 times, lol. It was really fun.
There was a point where I was able to get it in third gear, and even fourth, or so I believed, so I pondered if my clutch cable needed adjustment. I adjusted it and that seems to not have done anything, which is horrible lol. So at some point I will need to split the cases to figure out the issue, presumably. Although maybe I can drop the pan and find something visually wrong? Who knows.
Going to start it up tomorrow and let it idle a few times to see if the plugs change any bit. Then I guess I might go up a size from there.
Offline DaveBarbier
« Reply #487 on: September 04, 2019, 02:16:44 AM »
A little late, but yes these old bikes need some throttle unless you have a fast idle cam on your carbs which you don’t.
I’m confused why you’d need to split the cases. Did it shift or not? Any grinding? Popping out of gear? Shift lever locking up?
Offline Scott S
« Reply #488 on: September 04, 2019, 03:23:57 AM »
 That looks a little lean, but not bad. If your fuel has ethanol in it, it skews the spark plug readings a little bit.
 Do you have an IR temp gun? I like to shoot the headers, cylinders, etc., to get an idea of how hot the engine is running.
 Where did you end up on jetting and needle position?
'71 CB500 K0
'81 Yamaha XS650
Offline Marissa
« Reply #489 on: September 05, 2019, 06:03:24 AM »
It’s not shifting into 3rd again. It’s not popping out of gear, there’s no grinding either, it’s just the shifter locking up if I had to guess. Or maybe forks aren’t right. I don’t really know.
Offline Marissa
« Reply #490 on: September 07, 2019, 09:59:47 PM »
Okay. Got some more ride time in. Did at least 5 miles today. It's back to running rich again. It seems that the float valves were getting stuck again, at least somewhat. More fuel was in the drain lines, but it never started pouring out. It ended up getting difficult once it got hot and it stalled on me 3 times trying to get home. When I got home I found sediment in #1's line.
I also discovered today that I was not crazy and I do have all my gears. This seems to be dependent on heat -> viscosity. Today was the hottest I got the bike and sure enough I eventually got it into third, then so on and so forth. I confirmed by counting my downshifts.
I'm using OE Spec Honda 10W40. Is this something that could get better with ride time?
I don't have something to read temps unfortunately. I purged the carbs with an air hose in the drain tubes to "reset" the float valves and it seemed to actually work. So tonight I had to retune idle and it seems to be running lean again.
I guess I'll let it idle again tomorrow morning and see where that leads me. Here's some pictures from my adventures of stalling lol.
« Reply #491 on: September 07, 2019, 10:19:22 PM »
I run 20w50 in my old bikes in hot weather. Does Honda's oil have enough zddp in it for our old bikes? That could contribute to shifting problems. Are your pods oiled too much? That can cause rich conditions.
Are your bowl gaskets OEM or aftermarket?  Just wondering if they are swelling and fouling the floats.  If you are still seeing sediment in your overflow lines or float bowls then this sediment will be likely cause of overflow and rich running when it blocks a float valve from closing when the carb bowl fills full.
My $0.02
David
« Last Edit: September 08, 2019, 12:24:30 PM by RAF122S »
« Reply #492 on: September 07, 2019, 10:30:09 PM »
 i would not blow compressed air into an assembled carb
Offline DaveBarbier
« Reply #493 on: September 08, 2019, 10:23:22 AM »
Yeah, I don’t know what’s going on with your sediment situation. Maybe your pods are disintegrating...? Maybe everything just isn’t as clean as it should be?
For the clutch thing that could be oil related. What do you mean Honda spec oil? What’s the brand? Honda oil? I really like Spectro oils. They’re in Brookfield, CT. 15 miles from me. I use the semi synthetic and shifting is super smooth and it’s cake to find neutral at a stop light after it’s nice and hot on a hot day.
Online HondaMan
« Reply #494 on: September 08, 2019, 06:04:57 PM »
If blowing up the drain lines into the bowls worked (and hopefully you have plastic floats? Otherwise the floats were damaged, likely), then you still have sediment troubles making the float valves stick open to cause the overflows and too-rich running. There must still be a little bit of it trapped in the lines, petcock, and the fuel tees in between the carbs. It don't take much, with these tiny float valves, to stick 'em open.
I used to remove the floats and needles (this is on 750 bikes, though, where the bowls are easy to remove while on the engine) and then turn on the petcock to drain straight into a (long narrow) pan until I was SURE it was all flushed out. On bikes from Missouri, in particular, in the 1970s this was a trouble before the 'final filter' gasoline pumps showed up at AMOCO and SUNOCO gas stations, as those guys ran their station's tanks to dry sometimes, picking up crud on the way. It was also legal there (in those days) to have above-ground gas tanks, and when those ran low they would tilt them toward the exit spigots, delivering the rust and crud directly to the cars...
Offline Marissa
« Reply #495 on: September 12, 2019, 02:47:39 PM »
Dave, I checked the pods and they sure don't look or feel to be disintegrating. For now, I took them off just to see if this changes things. The oil I use is apparently called Pro Honda GN4.
For the past few nights, I've been starting it and just letting it idle or at least try to idle. Recently, the bike will not start with choke fully closed. It seems to like it 3/4 open to start. It will hold at 1/2, and 1/4 pretty well. But the bike does not seem to like choke fully open. It won't hold idle once the choke is fully open, regardless of how long it's been warming up. It needs throttle, and once it's given throttle it rev hangs and pops really badly. I pulled plugs and they aren't wet, they still look a little rich though. I'd assume it's rev hanging because it's too rich, but if that was the case, why wouldn't it rev hang at 1/2 choke? at 3/4?
Here's how the drain tubes looked too. Only 3 had a drop of fuel in it this time. These results are really inconsistent for me to feel totally confident its the float valves.
I'm going tear down the carbs one more time before I throw in the towel on this and give it to a shop to look at. I also figured out that the reason I have some wobble is not because of a flat spot, but the shop I brought the rims and tires to didn't true them before mounting and balancing them. I don't have a truing stand, nor do I have the arm strength or desire to tear these down and try to fix it myself because I consider this a safety thing, so either way, the bike is going to need to go to a shop soon. I have no idea what a dismount and truing job would cost but it needs to be done. I found this out when I had my boyfriend take the bike for a spin and I saw the rear wheel wobble. Obviously, I put the wheels and spokes together, and I didn't true them because I knew I wanted the shop to balance them and set them up, so I'm really confident this is the issue.
Offline DaveBarbier
« Reply #496 on: September 13, 2019, 05:07:39 AM »
Ok, yeah the pod idea was just a shot in the dark. Didn’t think it was the cause but worth a check I guess.
If it won’t hold an idle with the choke not in use but it will with the choke applied (when you’re fully warmed up) then you’re probably lean. A hanging idle is a lean symptom. Check for air leaks?
And I didn’t know you also had a flat spot. Flat spot in acceleration/throttle? I don’t see how a flat spot could be caused by a rear wheel wobble but yeah that has to be taken care of. You can true your wheels by yourself. Keep the tire on, no need to break it down. And a truing stand? I use a rod, some v blocks and saw horses. Make anything that lets the wheel spin freely. Hell, true it while it’s still on the bike, just take the chain off and back off on the brake. Truing isn’t hard, watching some videos will give you pointers on which spokes to tighten. If you saw the rear wheel wobbling down the road then that’s a pretty big out of true issue. Make sure the wheel isn’t wobbling on the axle either.
As for the carbs, I don’t know what else to say other than make sure they’re clean. Are you certain the tank, petcock and lines are not holding debris? I’m not totally clear on your carb situation, unsure if the floats are leaking or if there is still debris in the float bowls. Have you done plug chops at idle with new plugs?
Offline Cb750 Racer
« Reply #497 on: September 16, 2019, 07:35:47 AM »
Did you ever adjust the air/idle mixture screws when you rejected the carbs? The jetting will change fuel all along the curve you'll have to adjust these screws to get the proper air/fuel idling and transitioning off of idle.
Turbo Billet Block cb750
1975 Honda CB400f
1972 Suzuki GT750J
1984 Kawasaki GPZ900 Mr.Turbo Top Gun build
2002 Suzuki Bandit 1200 Turbo
1979 Honda CBX
1990 Mr.Turbo Kawasaki ZX11
And Dozens More...
Offline Marissa
« Reply #498 on: September 16, 2019, 05:38:58 PM »
I adjusted the idle air screws from stock location and turns all the way out to all the way in. This didn't solve it.
Turns out my problem was that the bolts for the slide elbows had started to back out due to the vibrations of the bike. I had bent the washers but I guess some of them weren't bent tight enough to grab the bolts. I found this by pressing on the spring loaded pieces and checking over every orifice on the carbs while it rev hanged. Sure enough it started to lower RPMs!
So I tightened up everything throttle related as best as I could. Throttle is super snappy now. Also tightened down the shifter on the spline a bit and secured the bolt with blue loctite and it's much better shifting into 3rd now.
Changed all the slows to 40s and that seems to have cured my popping issue totally. Also cleaned off the spark plugs and double checked gap. Found plug #2 was a little tight and I'm wondering if I accidentally altered gap when trying to put the plug in the hole.
Took the bike for another test ride Saturday and that was easily the smoothest and nicest ride yet... But it still ended in failure lol. Seems like all 4 carbs are overflowing slightly, and when the bike gets hot, it stalls out on me. Seems to stall after 8-15 minutes of ride time. Plug #4 honestly looked pretty good, the rest started to get pretty rich. I'm wondering if carb #1 is pouring the gas into the chamber instead of the overflow tube so the issue isn't so visible even though the plug is totally black.  The bike does not like throttle when it warms up after 10 minutes. I turned the choke on when it started to die down and didn't give it throttle to see if it was an issue of too lean/ too much air and this did nothing. And obviously giving it no throttle with it slowing down and it already upset isn't going to change it...
Plug #4
Vs. Plug #1 lol
One thing I'm becoming concerned about now is cylinder #1 seems to be running hotter than the rest of the cylinders. The other exhaust pipes are a nice brassy gold but #1 is purple and blue. The bike stalled on me Saturday and I pulled the pods off (I put them back on after I changed out the jets to 40 and that seemed to fix the popping issues) when I pulled the pod off for carb #1, I noticed all of this white smoke come out of the carb. I checked valve lash and it's perfectly in spec. I got the bike to start back up by putting my palm over the carb inlet and choking it of air completely then immediately pulling it off when gas got on my hand.
Could this be the ignition timing? But if so, wouldn't all the other cylinders also be consistent with the coloration of 1?
I'm wondering if maybe it's just SO rich that it's causing high EGTs (exhaust gas temps) for that reason and altering the color.
And now all the carbs have a least a little residual overflow.
I'm hoping to get the bike ready to bring to work on Oct. 5th for a car show we're having. The shop I was interested in bringing the bike to has yet to respond back to me so I may try this weekend to clean out the carbs myself again. Ugh. The end has to be close. These fuel filters are super fine there's no way new sediment is getting in there. So the sediment has to be from the fuel lines down to the carbs. There can't possibly be that much more that I'm missing. I'll take the lines off and blast air through them when I clean them next.
We are getting close. But reliability seems far, far away lol.
Offline jgger
« Reply #499 on: September 16, 2019, 06:30:04 PM »
Very encouraging report, you ARE almost there. Clear tube those carbs one more time, I would bet you are still a touch high on the floats.
Use a pair of pliers on those washers so they fit tight to the bolt. If the washers only have 1 bolt hole then there should be a place to bend it down also or they won't hold because it will just rotate with the bolt.
Just a few more tweeks and you should be good to go.  BTW having been inside the motor you will always be second guessing yourself. I wish I had a nickle for every time I rebuilt my race bike on the starting line while waiting for the flag to drop. That was the longest 2 minutes in the world! Dead engine banner drop start for desert races. So you are doing fine👍😎
