Author Topic: Carb Rebuild help, extra parts....  (Read 850 times)
Offline mkramer1121
« on: December 17, 2006, 03:07:05 PM »
I bought a set of Keyster carb kits from PartsnMore, and I just finished putting to carbs together.  However, have some extra parts.  I don't remember seeing this o-ring or this washer when I disassembled the carbs, and they're not floating around in my parts bag.  I also know that these kits fit a variety of years, so they may not be needed for my bike (CB750K4).  Any ideas?  I don't want to run into issues later on down the road, with leaks from odd places.  Thanks!
And since we're having issues uploading pictures, its the o-ring and washer above the needle clip in this link:
http://www.siriusconinc.com/ebayimages/KH0134N.jpg
Offline Raul CB750K1
Re: Carb Rebuild help, extra parts....
« Reply #1 on: December 17, 2006, 03:17:54 PM »
The O-ring is either for the air screw or the bowl drain screw, that you probably haven't removed and therefore you haven't noticed the o-ring
Raúl
kettlesd
« Reply #2 on: December 17, 2006, 03:24:21 PM »
If its the o-rign and washer from the airscrew, they tend to hang up inside the bore. Take a peek inside with a flashlight and you can see them. They come outeasily with a dental pick or very fine screwdriver.
Offline mkramer1121
« Reply #3 on: December 17, 2006, 03:26:58 PM »
Awesome, thanks to you both.!
Offline JW Miles
« Reply #4 on: November 02, 2014, 01:12:11 AM »
The oring is  a replacement and goes around the shaft over the slides,  The washer is for the screws you remove to sync your carbs..
