I hope that someone can help shed some light as to how I can improve my MPG from 29-30 MPG to hopefully over 40+!
Carbs was bench synced to 1/8 bit size. I'm running full stock everything except the pipes (26" EMGO cone 4-4) and the air filter (using the foam one TwoTired uses)
Now these pipes and the stock ones have been giving me the same MPG. I don't fuel when I hit reserve, I fuel after 30 or 60 miles, and do the math with the corresponding fuel it has taken me to top it off at the same volume.
I've recently done the following:
Oil/filter change last 1k Miles
Tensioner, valve clearance, point gap, timing, spark plug cleaned and regappped done in less than 500 miles ago
First the foam air filter needs to be clean and NOT over oiled.
An oversize front tire (taller) will make the odometer lie, which would effect the calculations. Changing drive sprocket ratios can make the engine turn more revs per mile. A stiff chain eats surprisingly more HP. Well lubed is better. Dragging brakes front or rear? Easy to check.
Do you warm up with choke on and standing still?
Er, I much prefer a vacuum sync.
Would be helpful to see what the spark plug deposits look like.
Also would be nice to know what the predominant throttle setting is during your rides and what gear you are in mostly. Not going to get good MPG in stop and go city traffic, remaining in first gear.
These factors in mind, I can tell you that the CB550 in stock trim used to get 50 MPG in highway cruise before the Gubmint took energy out of a gallon of gas by force adding ethanol. Must use up more fuel to make the same HP.
Still, I think 45-ish is a reasonable ask.
So, since you've addressed most everything outside of the carbs. Lets look in there to see what is or could be.
A leaking main jet oring ? Emulsion tube holes blocked/ restricted? Float bowl fuel level too high? Worn slide needle jet and or slide needle. Wrong taper slide needle? Slide needle clipped in too high position?
Some of the above can be inferred by reading the spark plug deposits.
Of course, non Keihin Brass bits may have the wrong dimensional measurements and contribute to poor MPG.
When all the above are addressed and confidence of correctness achieved, you might just make a modification to the mains emulsion tube by adding more holes at the needle positions related to cruise setting, to lean the mixture at that point. This will be a try and test procedure. So, best to have spare originals to fall back on, though you could just solder up some of the holes you added.
Then, I think the spark plug deposits patterns will tell you if it should be better at MPG.
