Author Topic: What's your favourite way to de rust a tank?  (Read 3633 times)
Offline Scott
  • 72 CB750
« on: June 12, 2017, 12:17:31 AM »
Hi, how's it going?
I de rusted a tank using hydrclauric acid last year and it worked fine....  but what are some ways you have had success with?
I need to do another one.8
Thanks for your time.
Scott
Offline dhall57
Re: What's your favourite way to de rust a tank?
« Reply #1 on: June 12, 2017, 03:53:26 AM »
The Works toilet bowl cleaner.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Deltarider
« Reply #2 on: June 12, 2017, 04:23:27 AM »
I'd start with a litre of diesel, slush it around and see where it gets you. Costs practically nothing and won't do any harm.
CB500K2-ED Excel black
Offline evopgt
« Reply #3 on: June 12, 2017, 04:53:08 AM »
I use Evaporust. Fill completely. Let it sit 24 hours drain it rinse it with water, then fuel rinse
Offline innovativems
    • Innovative MotoSports
« Reply #4 on: June 12, 2017, 06:29:46 AM »
Metal rescue has been my go to lately
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline Dracon
  • Wannabe Old Timer...
« Reply #5 on: June 12, 2017, 06:30:34 AM »
I used the works on my Ducati tank a few years ago and it worked brilliantly, but I went to buy some more just yesterday and the bottle color had changed - looked at the % of hydrochloride and it has been cut in half to 9.5%. The old stuff was over 19%. Maybe it'll still work okay, but probably not as good as it use to if it's the new blend. I didn't buy it so I can't comment.
« Reply #6 on: June 12, 2017, 06:32:43 AM »
Kleen Strip Prep-n-Etch.
Dries without flash rust
Offline JBCB500
  • Really enjoying this!
« Reply #7 on: June 12, 2017, 06:38:25 AM »
A couple of cups of muratic acid, then fill to the top with water.  You can buy it at Walmart for about 8 bucks and it'll do several tanks.  I've brought back some very rusty ones.  Try starting out by leaving it in for 2-4 hours depending on how rusty it is to start.
Offline Dracon
« Reply #8 on: June 12, 2017, 06:43:00 AM »
Just looked this up - $15.78 a gallon at Home Depot and has 35-45% phosphoric acid. Looks like I'll be picking some up today - thanks for the tip!
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #9 on: June 12, 2017, 07:39:47 AM »
Yea, I'm gonna try this next. Sounds promising, and very reusable. Will catch it in a Homer bucket with a lid to store and reuse. That brew is good for a lot of things around a restoration shop.
N.
I have a motorcycle problem.
Offline PlungerWaffle
« Reply #10 on: June 12, 2017, 07:55:06 AM »
I fill the tank with vinegar and pea gravel, then i shake it till my arms will no longer move and rinse it with distilled water.
« Reply #11 on: June 12, 2017, 07:56:11 AM »
I favor the elecrolysis method, as it will not remove the parent metal, as acids will, just the rust.
Don't have worry about leaving acid in too long.
Online Stev-o
« Reply #12 on: June 12, 2017, 08:01:22 AM »
+1
Offline slikwilli420
  • Master of Disaster
« Reply #13 on: June 12, 2017, 08:04:40 AM »
Can I do a liner over it like redkote or caswell?
Offline 700504
« Reply #14 on: June 12, 2017, 09:45:21 AM »
White vinegar to the brim for a week, then pressure wash it and fill with gas or slosh wd-40 in it to prevent rust.
1978 cb750k
1977 cb750f2
1974 cb750k
1973 cb750k
1981 cb650 (rip)
1969 ct90
Online Stev-o
« Reply #15 on: June 12, 2017, 03:46:11 PM »
Yes. In fact, thats a preferred step for preparing a liner; to first etch the surface after de-rusting.
+1 but dont use redkote.  Caswell...+++
« Reply #16 on: June 12, 2017, 04:29:13 PM »
Wow! Is that in your 350F, Rob?
« Reply #17 on: June 12, 2017, 04:47:31 PM »
Redkote won't crack as the others will and is a favorite among racers since things do happen on the track. As I read more about different liners, redkote can be redone or recoated easily where others cannot.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #18 on: June 13, 2017, 11:41:25 AM »
What is the mix ratio? Or do you use this undiluted? Just in that case, it would be an expensive proposal for a 6 gallon tank??
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
« Reply #19 on: June 13, 2017, 11:50:57 AM »
No need to fill the whole tank. I just did one yesterday and used 1 gallon, shaking around every half hour or so. Once the surface is wet, it will start working and inside a tank, it wont dry out.
It worked a little too well in fact, and now my tank is much holier than I originally thought. Getting really sick of super sport tanks. They are all junk.
« Reply #20 on: June 13, 2017, 12:04:41 PM »
No.  This is the 550K tank I did last fall.  Disappointed I didnt take a before picture of this one, but it was quite flash rusted.
Prep-n-etch treatment for 4 hours, water wash-out, acetone rinse, and then shopvac dried.
@MikeSimon
I just used 1 gallon of prepnetch, but ive got a bucket filled with old golf balls I add in, to reduce the volume of the tank.  Shake/rotated the tank every half-hour and you're golden. ;D
« Last Edit: June 13, 2017, 12:13:27 PM by flybox1 »
Offline markreimer
« Reply #21 on: June 14, 2017, 09:28:48 AM »
White vinegar. I bough 4 liters of it from the grocery store for about $5. Dumped it in there with a pack of sheet metal screws. Gave it a good shake a couple times a day, for a few days, came out pristine. This was for a 350F tank that was 100% covered in rust after sitting for over 40 years outside.
I followed up with an acetone rinse, then rinse with gas, and finally a Caswell tank liner treatment.
Offline markreimer
« Reply #22 on: June 14, 2017, 09:48:06 AM »
Hmm, you know, I may have only used acetone, but I can't fully remember since it was a couple years ago. But regardless, the Caswell liner has been 100% ever since!
Offline geoluv
  • Brooklyn, NY
« Reply #23 on: June 16, 2017, 10:31:16 AM »
Distilled water and sand.  $5 total.  I ate a big meal of carbs and protein then shook the crap out of it for 2 hours. Let's say 1 hour for every 10 years of rust  :P.  Rinse thoroughly with hose then dry with shop vac, normal house vac, or air compressor if you have it then fill to the top with gas and install brass element viso-filters if you aren't going to seal it.
1975 CB550K1 Candy Jade Green
1977 CB550F2 Candy Presto Red
Countless vintage bicycles
« Reply #24 on: June 16, 2017, 05:35:56 PM »
Is the Caswell method simpler than the POR15 method? And/or quicker?
