Author Topic: backfires through the exhaust on #3  (Read 1167 times)
Offline gto_ron
« on: June 16, 2017, 03:01:13 PM »
the first 15 minutes after starting cold cylinder #3 backfires through the exhaust, the float setting is about 5mm using the clear tube method.  I installed a new needle & seat anyway but it didn`t help. Where should I check next?  The bike is a 750K6
76 CB750K
72 CB350F
64 GTO
why yes, I am old-school, so what?
These are the good old days.
Offline Jimray23
    • none
Re: backfires through the exhaust on #3
« Reply #1 on: June 16, 2017, 03:03:20 PM »
Idle plug chop. Its typically lean carb causing that but also check the valve clearances
Jim
1979 kz1000b ltd
    stage 3 cams
    pod air filters
    4-1 open exhaust(no muffler)
    full rewire
    dyna-s ignition
    dyna 3 ohm coils
« Reply #2 on: June 16, 2017, 03:46:15 PM »
Do the spark plugs show different deposits among the cylinders?
Is there an exhaust leak?
« Reply #3 on: June 16, 2017, 04:19:13 PM »
Yes check the plugs. If it is on deceleration it is most likely a low float bowl level.
« Reply #4 on: June 16, 2017, 05:41:13 PM »
If that one carb slide is low (more than 2%) compared to the others, it will pop like that. Do you have vacuum gages available? If not, a visual check of the slides (carefully) will often help. Make sure they are all very close to each other, like maybe slip a drill bit into the back of each one to see which one(s) is higher than the others, etc.
Offline gto_ron
« Reply #5 on: June 16, 2017, 06:23:05 PM »
thanks for the responses, I'll get out to the shop tomorrow and put your advice to work.  I didn't mention this but the bike runs great after it warm up.
76 CB750K
72 CB350F
64 GTO
« Reply #6 on: June 16, 2017, 06:51:19 PM »
Aha! This can also be caused by a too-tight valve (lash). Check the clearance on the #3 exhaust? Should be 0.003"-0.004" at TDC for 2-3 with that one on compression stroke.
« Reply #7 on: June 16, 2017, 11:57:11 PM »
Bad connection between coil and plug? I have had similar symptom due to Dynatek coils automotive type of wire connection. The wire creeped out from the coil terminal
