Author Topic: Strange rear hub issue - CB550  (Read 6608 times)
    • http://forums.sohc4.net/index.php?PHPSESSID=a4e92u7e916fbbgkge611of6m3&/topic,60973.0.html
Re: Strange rear hub issue - CB550
« Reply #25 on: June 23, 2017, 02:04:28 AM »
if the retainer not are total inn..the vhole vheel can move to the brake plate side??
..i have the idea it vas the bearings and the senter tube(distance tube) vho made the posision..and hold it all korrekt placed..like on most smaller bikes..but then..vhy use it anyvay..Honda put it there ..not for fun..
Offline Scott S
« Reply #26 on: June 23, 2017, 06:59:53 AM »
Who put the bearings in?
My old man did... he said they all seated nicely and from what I can tell they are both seated where they should be.
The dust seal behind the sprocket cover is worn right down too. Every spaced seems to be present. I looked at the other style brake cover and I don't think that mine has been mixed up. Bit of a mystery!
 Are you sure you're not holding #5 in those pics? We're talking about #12, which seems smaller than the spacer you have pictured.
 I know for a FACT that not having it will cause the exact symptoms you're describing.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
« Reply #27 on: June 23, 2017, 07:40:40 AM »
I agree with Scott and would bet a little bit of money #12 part was not in place...
« Reply #28 on: June 23, 2017, 08:46:21 AM »
 The inner threaded retainer, that holds bearing in sprocket side of main hub.. I cant see it in the drawing ?
Am i just not seeing it.
When you guys say 12, do you mean 6 ?
  • I'm back
« Reply #29 on: June 23, 2017, 09:07:02 AM »
#3 is the rear wheel bearing retainer, #6 is the COLLAR, REAR WHEEL SIDE in Honda speak. This 'SIDE' was added in later parts lists so Honda probably understood there was some misunderstanding. This collar sits loosely behind the sprocket plate. #12 sits more inwards and is the COLLAR B REAR AXLE DISTANCE. I agree both the exploded view and the namegiving is not very clear.
« Reply #30 on: June 23, 2017, 09:10:54 AM »
3 looks like it holds a bearing into 10
The hub appears threaded, yet I see no retainer or the 3rd bearing , WTF..
Now its getting confusing.
Should there not be 3 bearings and two threaded retainers coming in from sproket side, like on a 750? #12 is both a spacer and adaptor to the larger id sorocket carrier bearing.
To me it looks like drawing missed a few pieces.
 Be confusing to the OP.
« Last Edit: June 23, 2017, 09:20:20 AM by 754 »
  • I'm back
« Reply #31 on: June 23, 2017, 09:25:07 AM »
It's because there's no 3rd bearing like the 750 has. Actually the CB500/550 hub design is poor. With the sprocket in place, it's quite useless to try to balance the rear wheel. On installing everybody forgets to place #6 before fitting the sprocket plate. After you've torqued the 4 nuts, you can remove them again when you find out you can not put the stepped collar #6 through the plate's hole. A few things to observe: the retainer has a reversed thread and does NOT necessarily have to lie flat against the hub.
« Last Edit: June 23, 2017, 09:29:30 AM by Deltarider »
« Reply #32 on: June 23, 2017, 09:28:23 AM »
So does 11 go against 12 ?
 Then it would flop over when you pull sprocket carrier off.
  • I'm back
« Reply #33 on: June 23, 2017, 09:35:49 AM »
I'm having dinner right now so if you don't mind, all of you, go to p.50 and 51 of this parts list http://www.honda4fun.com/pdf_parts_list/pdf_spac500/CB500-76/CB500-76_3.pdf that has a better pic. BTW you all should consult the parts lists instead of looking at the bloody fiches that never tell you the full story.
Offline DrJones
« Reply #34 on: June 23, 2017, 12:46:08 PM »
Yeah, I think you're onto something here. The spacer that I have is definitely the outer one (#6). I don't have a way to remove the bearing right now but just feeling behind it, all I can feel is #11. No sign of a spacer behind the drive side bearing!
« Reply #35 on: June 23, 2017, 12:49:40 PM »
Ready to get the manual?
 I prefer the Clymer over the Haynes..
Offline DrJones
« Reply #36 on: June 23, 2017, 12:54:13 PM »
I've got one!
Offline Scott S
« Reply #37 on: June 23, 2017, 03:39:47 PM »
 Told ya! ;)
 It's really easy for that spacer to get stuck in the old bearing and tossed out. There's a reason I know this....
'71 CB500 K0
'81 Yamaha XS650
Offline DrJones
« Reply #38 on: June 23, 2017, 04:41:31 PM »
 Told ya! ;)
Fairly certain that's what has happened.
Thanks for the help guys! We have an old 550 wheel kicking around to get parts from. Thank god, that spacer is pretty hard to find online.
« Reply #39 on: June 24, 2017, 09:17:49 AM »
I find the 500/550 easier than the 750, the sprocket side bearing is pushed into the hole up to a shoulder and stopped from coming out by the threaded retainer, which is why it is imperative that the retainer is in all the way. The other side bearing is fixed by the internal spacer and has no shoulder to but against.
Sorry if replies are intermittent but I am in UK so on different clock
Offline Johnie
« Reply #40 on: June 24, 2017, 02:17:46 PM »
So this goes all the way back to reply #3, aye?  ;) When I took mine out is was froze to the axle. When I finally got it out I put it in the new bearing so I would not forget it. It was my first 550K and it was a learning experience with that spacer. Good lesson and glad you got it sorted out.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline DrJones
« Reply #41 on: June 24, 2017, 07:03:25 PM »
Yep, you were right! I didn't realized there were two spacers initially... oh well.
Looks like that spacer is unavailable everywhere. My friend is going to make one on his lathe for me.
« Reply #42 on: June 24, 2017, 09:12:30 PM »
20 mm ID step is likely 25 mm
Not hard to make..but you need measurements.. Good luck.
