Author Topic: Am I missing something?  (Read 1164 times)
Offline ChopSticks
« on: June 24, 2017, 06:48:47 AM »
I'm starting to feel real stupid... just doing a simple oil and filter change. Manual says put 3 qts in. I put in about 2.5 and it's almost to the top of the filler cap. So then I measure the oil I took out and it's only 1.5qts? I kicked the engine over a few times while the oil was draining to get the last little bits and even kicked it over to fill but now it's not draining to the engine?
Note this is all done on the side stand, does it need to be on the center?
Offline terjla
Re: Am I missing something?
« Reply #1 on: June 24, 2017, 07:00:05 AM »
Always on center stand...Is it 750 Four?
Offline innovativems
    • Innovative MotoSports
« Reply #2 on: June 24, 2017, 07:00:26 AM »
The bike must be level
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline ChopSticks
« Reply #3 on: June 25, 2017, 09:19:37 AM »
Ugh alright I'll drain and refill again. If I already changed the filter would I need a new one? I did turn the engine over the first time via starter just to try to get the oil to drain into the engine...
Also the engine is a 750F after taking the filter out and reviewing the OEM parts finder I noticed there were a few parts missing, specifically:
5    15414-300-000    SEAT, OIL FILTER SPRING    $4.98
10    15473-300-300    VALVE, CHECK    $4.95
11    15474-300-310    SPRING, CHECK VALVE    $4.64
12    15477-300-300    PIN, SPRING SETTING    $4.13
http://www.gearhead.com/oempartfinder.htm?aribrand=HOM#/Honda/CB750FA_(78)_750_SUPER_SPORT,_JPN,_VIN%23_CB750F-2200001/OIL_FILTER_+_OIL_PAN/CB750F-78-JPN-A/2Y134102AE13410212A
How important are these parts? I'm going to put in an order which will take a couple weeks, just wondering if I should not be riding or even turning over the bike without these?
« Reply #4 on: June 25, 2017, 09:28:13 AM »
Why waste 2.5 quarts? You did a partial oil change. It is now MUCH better than before. Use it.
