Author Topic: $100 1978 Cb750 project  (Read 6658 times)
Offline Rydog400f
« on: June 24, 2017, 07:38:20 AM »
Picked up this little gem from a friend. Motor was seized and it was missing the title. A little over a week of marvel mystery oil and the cylinders freed up with ease and a little schmoozing at the dmv brought the $610 late fees and penalties down to $400. Thinking about just bringing it back to stock but am kind of leaning towards a gl1000/ '76cb750 spoked wheel conversion. I'm pretty sure this year came with a painted engine which is chipped pretty bad. Other than that I changed the oil, plugs, battery, and cleaned the carbs and it fired up! Easiest project bike I've started in a while!
Sent from my HTC6545LVW using Tapatalk
Offline firebane
Re: $100 1978 Cb750 project
« Reply #1 on: June 24, 2017, 08:10:08 AM »
As I mentioned in another area you have a F model bike which are a bit more sought after.
« Reply #2 on: June 24, 2017, 06:07:19 PM »
The F models had black painted engines.
The F1/F2 have comstars and probably the best CB750 SOHC4 brakes.  The GL will give you slightly more stopping power and 37mm (versus 35mm) diameter fork tubes.  You will need to do a complete swap though -- triples, forks, brakes, wheel, rotors, etc.  If you were swapping from a K model, I might recommend it, but here I don't really think the juice is worth the squeeze.
Offline Rydog400f
« Reply #3 on: June 25, 2017, 08:10:29 AM »
Yeah after doing more research I think I've decided not to do the swap and really just bring it back to stock with the vfr brake upgrade.
Offline Rydog400f
« Reply #4 on: July 08, 2017, 05:22:04 PM »
Got some more work done today and had a LOT of parts come in. I bought what I though was cb900f front and rear brakes. But it looks like the front is for a 900c and the rear is a cb900f. The 900c won't fit the 750f mounts. Got a new headlight and some other bits. Tank is being prepped for por15 now. I'm also having trouble finding a 22mm petcock. Any help is much appreciated!
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #5 on: July 08, 2017, 05:57:13 PM »
Aftermarket fuel valve (scroll down):
http://www.vintagecb750.com/products/6/fuel-system/67/fuel-petcocks-gas-tank-caps-and-parts
Fitment is determined by measuring the OD and thread pitch of the threaded bung on the bottom of the tank. Be sure to pull the old filter out of the bottom of the tank from inside the petcock bung. New filter can still be had from Honda:
http://www.hondapartsnation.com/oemparts/p/honda/16952-388-015/screen-set-fuel-strainer
How much do you want for the old petcock?
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #6 on: July 08, 2017, 06:13:41 PM »
That's a bummer about the front calipers.  I imagine the dual piston 900f calipers should improve the stopping power.  Hopefully the seller will take back the wrong calipers.
Those rotors could use a little TLC, too.  I wouldn't ride on those shocks either.  I'm looking forward to seeing you bringing this one back.
« Reply #7 on: July 08, 2017, 06:15:00 PM »
It's funny because 10 years ago, that wasn't the case in California.
Offline Rydog400f
« Reply #8 on: July 08, 2017, 06:35:33 PM »
I hope I can just find the 900f brackets and bolt them on. Oh yeah I wasn't planning on riding it with the rotors/ shocks this way. Rotors will get honed and drilled and  ordering some hagons shocks.
« Reply #9 on: July 08, 2017, 07:25:23 PM »
Subscribed.   You have a name for this bike yet?
Online seanbarney41
« Reply #10 on: July 08, 2017, 11:16:45 PM »
I dont think that is the case anywhere... its funny because f parts are precious, but the whole bike aint worth #$%*.  Don't get me wrong, I love the F's, you just cant sell em.
« Reply #11 on: July 09, 2017, 04:11:11 AM »
Wow, that brings back memories. I bought an F2 like yours for $400 on ebay 12 or 13 years ago and spent a small fortune restoring it. Thanks to Photobucket holding my pics hostage, I can't show you a before and after pic now, but it looked better than new when I'd finished. It was a great bike when I finished it, but as has been said before, they're worth nothing compared to early "K" series bikes, and I lost several thousand dollars when I sold it. Great bikes, but I'd never restore another one. Cheers, Terry. ;D
« Reply #12 on: July 09, 2017, 09:09:05 AM »
I thought that was still the case, but I have never tried to buy or sell one.
« Reply #13 on: July 09, 2017, 09:26:43 AM »
I'm glad I'm not thinking about selling my K3 when I'm done. If I added up the costs there would be no way to break even. These bikes are expensive to bring back. I still have some pretty pricy things to get such as calipers, maybe a master cylinder, various nuts and bolts, pistons and I assume valve guides. Oh, I also will be getting progressive fork springs and shocks. It adds up quickly. If I were to sell it someone would want to buy it for what it sold for in 1973. Do it for the joy, not the money. Only a very few vehicles make money. I suppose if someone had a very low number K0 it might bring in real cash. I'll just enjoy putting around with my wife as other "guys of a certain age" look at me and wonder where the bike came from and dream of their youth. :-))
Offline Rydog400f
« Reply #14 on: July 09, 2017, 01:09:33 PM »
That's how I feel too. I've never really built a bike to make money. If I'm lucky I'll make a few hundred. After the first one the money just gets recycled from one to the other.
Offline Rydog400f
« Reply #15 on: July 09, 2017, 01:13:09 PM »
Well I guess I'll keep it. The bike had a full tank when I got it and it wasn't leaking. I think I'll just try to replace the rubber washer and reuse it. Thanks for the link!
« Reply #16 on: July 09, 2017, 03:16:04 PM »
The new strainer/filter comes with a new gasket for the petcock. Be sure to get all of the old gasket out.  8)
TAMTF...
Wilbur
Projects:
Offline Rydog400f
« Reply #17 on: July 16, 2017, 06:02:38 PM »
Got the front brakes sorted. Picked up a pair from an '85 honda shadow for $25 and they bolted right on. Plus they're in way better shape than the original! Almost ready to tear the bike down for powder coating. Just trying to figure out what kind of seat to go with. My wife and I decided it would be a single  seat. I've been trying to find something that would allow me to use the stock hinge and seat lock. Also looking into the handle bar setup. I have some super motos on now but like the look of the Hyde m bars.
« Reply #18 on: July 16, 2017, 07:58:13 PM »
Another member converted his 2-up Super Sport to a single.  The build currently escapes me, but it use the stock hinges as well.
Offline Rydog400f
« Reply #19 on: July 16, 2017, 08:02:31 PM »
I've seen a few. I think the Corbin seat is Bolt on.
Offline Farley121
  • 78 CB550K
« Reply #20 on: July 17, 2017, 07:26:44 PM »
 IIRC, Carpy has a fiberglass cafe seat that used the the original seat hardware.
Offline Geeto67
  • A grumpy
« Reply #21 on: July 18, 2017, 10:04:45 AM »
If you can find one, Giuliari made a special seat for the F model supersports in the 70's/80's that used the stock hinges and locks. they are a bit wild looking and rare as hens teeth but they are out there and you can find them:
Maintenance Matters Most
Offline Rydog400f
« Reply #22 on: July 18, 2017, 11:12:39 AM »
Woah!
« Reply #23 on: July 18, 2017, 11:14:17 AM »
If that's wild looking, it's definitely wild looking in a GOOD way!!  Very cool, although I'd avoid white as the upholstery.
« Reply #24 on: July 18, 2017, 01:51:47 PM »
Better than some of the other ugly colors I've seen
