Author Topic: Life of a chain  (Read 1855 times)
Offline BallAquatics
    • https://vintage.dennisball.us
Life of a chain
« on: June 29, 2017, 10:44:27 AM »
I got 13000 miles on the first chain on my'74 CB550. Just installed a new one today and was wondering how long it should last with proper care?
Dennis
Dennis...  74 CB550  79 CBX  82 Seca Turbo  2011 CBR  2012 NC700X
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Life of a chain
« Reply #1 on: June 29, 2017, 10:50:59 AM »
13kmi is exceptional!!!
I try to get my chain to last the life of the tires.  6-8k.  Thats good for cheap chain.
Offline Gene
  • Chat enuf you too can be a
Re: Life of a chain
« Reply #2 on: June 29, 2017, 10:51:37 AM »
I suppose it would depend on the chain - brand, type, quality.  A cheapo chain won't get you long, it'll stretch out quickly.
*1973 CB750K3 (Bow)
Re: Life of a chain
« Reply #3 on: June 29, 2017, 01:32:43 PM »
I have gotten 18,000 miles.. Three tires..lots of laying rubber..
 My buddy got about 42,00 miles on a Diamond XDL..!
Chain care makes a difference.
Re: Life of a chain
« Reply #4 on: June 29, 2017, 02:22:51 PM »
Sure does, also avoiding sand, riding in the rain.  And getting a chain made with high durability metals.
Whether it is on old or new sprockets matters also.  Worn sprockets make a new chain wear faster.
The second chain on used sprockets never lasts as long as the first one to mate with the new sprockets.
Offline Gene
Re: Life of a chain
« Reply #5 on: June 29, 2017, 02:29:03 PM »
This.
*1973 CB750K3 (Bow)
Re: Life of a chain
« Reply #6 on: June 29, 2017, 05:46:06 PM »
I think 15k miles is reasonable out of an o-ring chain.  I got 27,000 out of the original 630 chain on my 750f3 with little to no maintainence by me or the previous owner/s.
Offline 333
  • Time for change
Re: Life of a chain
« Reply #7 on: June 30, 2017, 06:11:24 AM »
I never replace a chain without changing sprockets as well.  That way, I'm never disappointed with it's life span.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Re: Life of a chain
« Reply #8 on: July 02, 2017, 10:22:14 PM »
I've run the Diamond XDL more than 45,000 miles, and only then changed it at 1.5% stretch because I wanted to: even the sprockets were still in good shape (I still have those, 30 years later, in the box). Oil it every 2nd tank of gas (moly-laced Kal-Gard lube in my case), wash it full force at the carwash whenever I wash the bike, then ride 5 miles to fling out the water before lubing it again, lube it warm, usually.
I've never seen anything outlast the Diamond XL or XDL. Even their modern version, the Powersport, only gives me about 25k-30k miles. Harlel shops today still carry the XDL...if you can afford their prices! :o
Re: Life of a chain
« Reply #9 on: July 02, 2017, 10:26:58 PM »
Hope you kept the rear sprockets...might still be runnable..
Offline 74cb750
Re: Life of a chain
« Reply #10 on: July 04, 2017, 03:18:50 AM »
true that!
Guess I usually buy cheap chains as I've never had one last more than 9, 000 miles.
Will hav e to try a better chain/o-ring for my next bike (either the cb350 or cb500 projects)
Laugh at least once a day.
Life  $ucks, then you die.
Re: Life of a chain
« Reply #11 on: July 04, 2017, 10:05:39 AM »
Oring chains on CB550s and 500s can score the engine cases.  Better check clearance.
Offline The Machine
Re: Life of a chain
« Reply #12 on: July 24, 2017, 02:34:31 PM »
I have a 75 CB550, what's a decent brand that's not too expensive for a non o ring chain you'd recommend? I see them for all sorts of prices. Also what size, 530 100 link?
Re: Life of a chain
« Reply #13 on: July 24, 2017, 06:13:36 PM »
I've gotten decent service out of DID 530 standard chains.
I don't remember the number of links.  And my books are 700 miles away. Sorry.
Offline Gene
Re: Life of a chain
« Reply #14 on: July 24, 2017, 06:16:53 PM »
DID 530 100. Inexpensive but not "cheap". or was it 110?  I think it was 100.
*1973 CB750K3 (Bow)
Re: Life of a chain
« Reply #15 on: July 24, 2017, 06:32:58 PM »
Depends on the quality, the strength rating number and how you take care of it. Cheap chains won't last so long. It's a good place to make an investment.
Offline The Machine
Re: Life of a chain
« Reply #16 on: July 24, 2017, 06:35:40 PM »
Thanks, it's 100. I counted the links on my old chain.
Re: Life of a chain
« Reply #17 on: July 24, 2017, 08:24:06 PM »
+1, what he said...
I just finished a 550 with well-sawed sprocket cover from using an O-ring chain, had to replace the cover.
