Author Topic: diy rectifier  (Read 5351 times)
Offline bert96
  • past ride
diy rectifier
« on: June 29, 2017, 11:54:56 AM »
 I need a rectifier(2 wires) for my Honda S65,i would like to do it instead of buying one.They ask 40-60$ for this little thing!?Anyone got a link on how to do it and where to buy
materials?
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline vfourfreak
  • Do you think that's wise
Re: diy rectifier
« Reply #1 on: June 29, 2017, 12:47:54 PM »
Lots of projects like this are to be found on Instructables
e.g. http://www.instructables.com/id/Make-A-Bridge-Rectifier-From-Diodes/
Kev
    • http://forums.sohc4.net/index.php?PHPSESSID=s27ti0o5mtb8kvkglgf1190450&/topic,60973.0.html
Re: diy rectifier
« Reply #2 on: June 29, 2017, 01:08:04 PM »
think you can use this(12v) its have both diode brigde and stabilicer..it can be faund as 6v too..can be used both as a one vire and 2 vires aut of the stator..have to make a jumper to use it for 1 vire auttake
the 2 diragrams is the 2 vaus to konnekt the same unit..vho is a lowcost one..used on italy and chinese bikes
« Last Edit: June 29, 2017, 01:13:38 PM by strynboen »
Offline bert96
  • past ride
Re: diy rectifier
« Reply #3 on: June 29, 2017, 01:13:36 PM »
I remember an old thread about homemade rectifier for our
Sohc 4,I thought I could do the same for my s65.
Bert
Re: diy rectifier
« Reply #4 on: June 29, 2017, 01:15:10 PM »
you can use a 220volt elektric unit too they comes in both 2 and 3 fases..and vork fine on low volt systems..so yes its easy..
Offline jaguar
Re: diy rectifier
« Reply #5 on: June 29, 2017, 01:15:58 PM »
Re: diy rectifier
« Reply #6 on: June 29, 2017, 01:16:58 PM »
he he he.. ;)
Offline bert96
  • past ride
Re: diy rectifier
« Reply #7 on: June 29, 2017, 01:19:15 PM »
You did not see my rectifier ! !
It does not look like that!! ;)
Will post picture.
Bert
Re: diy rectifier
« Reply #8 on: June 29, 2017, 01:20:42 PM »
here is a good one..can get it as 2 and 3 fase..and costs not a lot..like a cooling plate(..and not shure if it need to be isolated from the frame)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: diy rectifier
« Reply #9 on: June 29, 2017, 01:21:32 PM »
he he he.. ;)
Ichiban cracks me up...  ;D
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline bert96
  • past ride
Re: diy rectifier
« Reply #10 on: June 29, 2017, 01:23:15 PM »
Here,
Offline bert96
  • past ride
Re: diy rectifier
« Reply #11 on: June 29, 2017, 01:25:46 PM »
Someone can school me on how to do it?
« Last Edit: June 29, 2017, 02:28:36 PM by bert96 »
Re: diy rectifier
« Reply #12 on: June 29, 2017, 01:26:15 PM »
i have the same on my cd 50..its only a half vay diode.so it are not a 2 fase system
.so you onlu get the half sinus kurve..but for a small battery..it just can hold it going 6v 4 amp normaly..a zenor diode can do the same job..they are valued for spec voltage..but im not Expert on them...let us vait for the Experts to ring the door bell
« Last Edit: June 29, 2017, 01:29:58 PM by strynboen »
Offline bert96
  • past ride
Re: diy rectifier
« Reply #13 on: June 29, 2017, 01:29:01 PM »
Sorry,but,someone can explain me clearly! ;)
Re: diy rectifier
« Reply #14 on: June 29, 2017, 02:14:37 PM »
Looks like your old rectifier is a selenium type.
Only has to poles so it is still just a diode.  Passes current in only one direction of flow.
You can replace with a silicon diode.    Your schematic should show what the polarity should be for new diode installation.  Get one that has a 25V or higher withstand.
Do you also have a voltage regulator?
I ask because selenium usually drops near a volt and silicon drops less.
Any electronic stores near you.  Where did you plan a purchasing a replacement diode?
Offline bert96
  • past ride
Re: diy rectifier
« Reply #15 on: June 29, 2017, 02:21:22 PM »
I don't think this bike have a regulator.The other owner told me there was a problem with it,and I rebuild this bike,so why not install a new one!?
Is there any other number I should look when i'll buy a rectifier?
There is 4 pins on the one I see,where do put my wires?
Offline bert96
  • past ride
Re: diy rectifier
« Reply #16 on: June 29, 2017, 02:30:13 PM »
Is this one good or not,
http://www.ebay.com/itm/5pcs-KBPC2510-KBPC-2510-25A-1000V-Bridge-Rectifier-/152345634967
Is there any quality in these rectifier? Which one is the best?
Bert
Re: diy rectifier
« Reply #17 on: June 29, 2017, 02:30:41 PM »
4 pin rectifiers have four diodes inside them.  Usually have labels, two will have  ~  symbol (AC input).  And the other two will have + an - signs.
Your bike have positive or negative Ground?  If you have have a positive ground machine, you'll probably want to pick an AC terminal from the power generator, and a + terminal for the output to battery.
I haven't seen your circuit diagram, so there is some fuzziness about hook up details.
Re: diy rectifier
« Reply #18 on: June 29, 2017, 02:32:34 PM »
Bert
It will work.
Offline bert96
  • past ride
Offline bert96
  • past ride
Re: diy rectifier
« Reply #20 on: June 29, 2017, 02:37:48 PM »
Re: diy rectifier
« Reply #21 on: June 29, 2017, 02:48:45 PM »
he he he.. ;)
This is my fav....
I should have sent him my K4 jugs for 836!
Re: diy rectifier
« Reply #22 on: June 29, 2017, 03:47:14 PM »
Is this one better?
https://www.amazon.ca/Single-Phase-Bridge-Rectifier-KBPC5010/dp/B008DEU18G
For certain applications, yes.  For yours, it will work, but it is technically over spec.
Offline bert96
  • past ride
Re: diy rectifier
« Reply #23 on: June 29, 2017, 03:53:10 PM »
Did you take a look at the wiring diagram I post?
Bert
Re: diy rectifier
« Reply #24 on: June 29, 2017, 04:06:10 PM »
Connect the red wire to the + terminal, and the white wire to either of the AC terminals.
