Author Topic: LONG term gas tank storage  (Read 1591 times)
Offline eigenvector
« on: July 02, 2017, 08:54:24 PM »
Let's say you want to store a spare tank for a LONG time - like years.
While filling it up with gas is the most common - would there be a benefit to filling it up with something else, something more stable like antifreeze or actual oil (cooking, used motor oil, etc)?
I don't like storing gasoline for a few reasons, chief among them is that gas is combustible and dangerous to handle.
How do museums store gas tanks - empty but lined?  full of something inert?  Or do they just let them rust from the inside, maybe with some desiccant tossed inside for good measure?
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: LONG term gas tank storage
« Reply #1 on: July 02, 2017, 09:30:23 PM »
Bloo had an empty tank and old kreem liner when I found her.
Trash Can's tank has been sitting for a couple of months with two stroke oil.  Had gas in it for a little bit.  But drained that when I took the chassis to the exhaust fabber.
The gsxr has an aluminum tank that didn't seem to mind sitting with gas for a year.  Also sat empty since siphoning the old crap out.  No big deal.
« Reply #2 on: July 02, 2017, 09:47:10 PM »
I usually put in a mix of gas and oil (about 20% oil) and roll that all around, then drain it all out and store the tank open. But, here it is very dry, so it might be better to store it closed if it is humid where you are. In any case, leave the petcock open on RESERVE to drain anything that may condense inside over time (presuming it is level, for that). I mostly hang them on a wire or peg, so any condensation would end up in the front: hopefully the residual oil would, too, to protect the metal there.
If you can find it, get some LPS1 (not 2, or 2.5, or 3, but LPS1) and use it instead of oil. This stuff is amazing: it has such a strong affinity for metal that it will get under corrosion and lift it off after a while. Not cheap, but excellent stuff - Made in Georgia, USA.
« Reply #3 on: July 02, 2017, 10:12:53 PM »
+1 two stroke oil
« Reply #4 on: July 02, 2017, 10:29:43 PM »
subscribed
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #5 on: July 02, 2017, 11:20:51 PM »
+1 two stroke oil
+2 and the petcock works real smooth after that too.
Offline eigenvector
« Reply #6 on: July 03, 2017, 03:38:19 AM »
Okay - that wasn't so hard.
Plenty of places to get 2 stroke oil or similar.  LPS-3, definitely not a cheap high by any means - but it's not like I'm going to drink the stuff.
It sounds like a reasonable compromise between gasoline - dangerous to handle and limited to no protection and antifreeze (or the like) - incompatible with fuel but loaded with corrosion inhibitors.
Rob
1977 CB550K
1983 VF750S Sabre
Offline Scott S
« Reply #7 on: July 03, 2017, 04:07:42 AM »
 2 stroke oil or a few shot glasses worth of Marvel Mystery Oil. This is after making sure the tank is clean, bare metal and dry before pouring in the oil.
 Any local auto parts store should have freeze plug repair kits. Get one of those for the filler neck. On tanks with a screw on petcock, the cap for the A/C system filler on a car fits perfectly. On tanks with the petcock that takes two screws to hold it on, I have a thick piece of rubber....about 1/4" thick, I think it was an old conveyor belt....and I cut a piece in the shape of the petcock "footprint", drill two holes in it and use the petcock screws to hold it on. I usually do that when cleaning the tank and just leave it like that once it's cleaned and oiled.  I see no reason you couldn't install the petcock.
 Just drain out any excess oil and fill with gas. Those couple of ounces won't hurt. Might smoke for just a second, but probably not.
 Give the outside a good coat of wax and store inside. I put mine in the spare bedroom, away from temperature swings and sunlight.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline eigenvector
« Reply #8 on: July 03, 2017, 04:12:06 AM »
Actually it's simpler than that - a 3/4" galvanized pipe cap fits a petcock drain perfectly.
The tank in question here is a '78 CB750K tank.  I don't own a CB750 SOHC, but the tank paint is perfect and the interior is without rust - I want to keep it that way since in Seattle it will eventually rust from humidity alone.  So far I've been fortunate - but that won't hold forever.
Rob
1977 CB550K
1983 VF750S Sabre
    • http://forums.sohc4.net/index.php?PHPSESSID=840nmmsqjurpn8q0u7g7g2rl92&/topic,60973.0.html
« Reply #9 on: July 03, 2017, 04:55:04 AM »
i fill a dl diesel in my tanks.. turn them araund ,a few times..and tapp the rest aut of the tank..there is still a bit back..so renember to block the tap...not nice to get diesel aut at the attic
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #10 on: July 03, 2017, 05:06:35 AM »
So do I. Fill it up with diesel and store it. Probably least expensive.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
  • Holy Cow! I'm a
« Reply #11 on: July 03, 2017, 12:37:02 PM »
Diesel, cheap?  Where are you buying that?!
« Reply #12 on: July 03, 2017, 12:47:14 PM »
diesel kosts only 7 kroner pr liter..in denmark ;)
Offline Steve F
« Reply #13 on: July 03, 2017, 03:13:32 PM »
I drain the tank completely and leave the cap off to totally dry out.  I have a spray can of "Fogging Oil" which I then spray in the tank to coat the inside.  Make sure you wipe up anything on the paint and keep the cap off and the filler neck covered with a paper towel so nothing get inside.  Pristine and rust free.
« Reply #14 on: July 03, 2017, 05:36:46 PM »
FYI...7 Danish Krone equals 1.07 US Dollar.........
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #15 on: July 03, 2017, 06:13:38 PM »
...which would be $ 4.05 per gallon, which is expensive. Today, here in Ohio, I pay $2.18 per gallon of Diesel.
That should be less expensive than the same amount of 2-stroke oil, or?
1973 CB350F -sold
Other Hondas:
3 x CBX
CB1100R
GB500
Offline Menno
  • www.tanklackieren.de
« Reply #16 on: July 05, 2017, 02:36:47 PM »
You don't need a gallon of diesel. Maybe half a liter. Fill it in your tank and rotate your tank for a while.
Let the diesel out. The diesel left in the tank will stick on the metal surface for a really long time.
I would also recommend diesel.
Offline Bodi
« Reply #17 on: July 05, 2017, 03:30:16 PM »
I toss in some mothballs. The vapor displaces the air eventually... no oxygen = no rust. Stored a few tanks for many years in a shed with just "don't freeze" heat, still clean. Mothballs last a year at least, then add new ones.
