Author Topic: Help...advice needed, stripped threads on hub for retainer ring (CB500)  (Read 1914 times)
Offline etout00
Hi all, I'm hoping I can get this fixed without having to install a replacement hub. I was replacing my bearings on my front hub and slipped while driving out the bearings....hitting the threads for the retainer ring seat
1973 CB500 (same/similar Front hub as CB550 and 750)
The bearings are out and the hub is otherwise perfect...except for the top 2 rows of threads for the retainer ring (couple areas on the top 2 rows were hit by my hammer)
Any suggestions for fixing the threads? I don't have a tap nearly that large.
Thanks
Offline Eight
 A thread file , good eyesight, a steady hand and much patience .
I don't like cutting away metal with a tap.  The metal was bent to get where it is now.  Bend it back.
Think small chisel and find one that fits in the undamaged grooves.  Then use that to tap the threads back into line.
The other suggestion is to modify a tap so it rolls the  metal back into place.  Instead of cutting away using a sharp edge, make the entry side into a plow shape, so it will push the metal back to original position.
Sometimes you have to pay for your mistakes.  It's part of the learning process, on occasion.  If you are unsure, take it to a machinist.  If he tells you what you want hear, pay him to save the part.
Offline slikwilli420
  • Master of Disaster
With a cast hub, its very unlikely you will be able to bend it back with any degree of success. A thread file, as suggested may work. Worst case is needing to remove those threads (Dremel or similar) and use a tap of the same pitch to dress what is left, then thread the retainer back in.
Offline MoMo
  • Ride like you're invisible
You can do that just take your time
Offline CycleRanger
  • No comment about being an
In the past I have used a new retaining ring as a tap to carefully reshape distorted threads.
Grease it up and slowly work it back and forth to straighten the threads.
In combination with a little careful, patient file work you can probably salvage the threads.
Offline etout00
Thanks for all the suggestions. I'm really kicking myself on this one as the threads were perfect before I hit them with the hammer, the original retainer ring came out very easily by the way.
For what it's worth, I have a brand new retainer ring and will try to file the mashed threads.
Offline MoMo
Take your time, I'm sure you can make it work...Larry
Offline Airborne 82nd
I've done it this way what I used was a tool out of a set of engraving tools. The ones for leather don't cut the metal as much you push the tool no hammer. I'm sure you could make one I'm just showing the link to give you an idea :)
http://www.ebay.com/itm/2-Jeweler-Gunsmith-Engraving-Graver-Tools-Renard-Vautier-Used-/172761248539
« Last Edit: July 05, 2017, 11:38:06 PM by Airborne 82nd »
Use a shortened tap in a tap holder, then use it like a comb or rake to slowly. Cut the thread back into shape.
 I would not use new retainer, other than to check the fit.
Offline etout00
Success. I used a thread file and carefully filed out the mashed threads. The bearings are in and the retainer ring is back on.
Offline MoMo
Good, how long did it take?
Offline etout00
Not nearly as long as I thought it would, maybe 15-20 minutes with cutting oil and taking my time.
