Actually, no. The four cylinder pushrod is aluminum with steel on each end, why it is prone to breakage (or separation). The much earlier twin cylinder pushrod is solid steel. The four cylinder pushrod was made dual material so it would expand at the same rate as the clutch, giving optimumly consistent lever feel and clearance. The two rods will interchange, I and you have done it, but it ruins the designed-in temperature compensation. There is a felka on the sister Euro SOHC board reproducing these pushrods, not sure but I think one-piece steel. Also, CMSNL shows one -323 rod still in stock as if yesterday.
I did not see Mark's post. Didn't mean to repeat that, I was attempting to reply to the person who said the rods were the same.
