Author Topic: STEM Nut on 750K0  (Read 683 times)
Offline DickL
  • Really really old
STEM Nut on 750K0
« on: July 09, 2017, 03:50:03 AM »
Could a undertorqued stem nut cause the front wheel to hop? Mine was torqued to only 30 lbs
1970 CB750
1999 Honda Valkyrie
Offline calj737
  • I refuse...
Re: STEM Nut on 750K0
« Reply #1 on: July 09, 2017, 04:52:12 AM »
Only if it allowed the steering stem to ride loosely within the stem bearings. Wheel hop is normally associated with a wheel out of true, out of balance, or improperly filled forks. I typically find a "ratcheting" type of behavior from the front end when the stem is loose (front-to-rear notchiness).
« Reply #2 on: July 09, 2017, 10:27:37 AM »
30 in-lbs, or 30 ft-lbs?
If it has the OEM ball-and-race parts, it is only about 24 in-oz. (1.5 in-lbs). If it has tapered steering head bearings, it can go up to 5 in-lbs, but that will make it steer stiffly.
