Author Topic: The Lost Socket Garage  (Read 85912 times)
Offline Gurp
  • I'm no.......
  • Once was a...
Re: The Lost Socket Garage
« Reply #325 on: May 20, 2019, 07:26:28 AM »
Nerve racking...
300 bones plus shipping...
Thats like a whole 5 day paycheck.
slow Progress 74 cb550.
Poor boy chop 73 CB500 chop
"Alley Cat"  93 sportster
Offline Scott S
« Reply #326 on: May 20, 2019, 08:53:38 AM »
 It is a lot of money, but I got the bike cheap. Going by what SR500's are selling for these days, I'm still not upside down on it.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Scott S
« Reply #327 on: May 20, 2019, 11:43:27 AM »
Well, I've put about 5 miles on her riding around the neighborhood. When she runs, she runs great. Falls into a nice idle (~1100 RPM), pulls pretty clean. Seems to really kick in over 3K RPM, probably when the pumper carb gives it a little extra juice. No real popping or backfiring anywhere; just a minor "chuff, chuff" on decel. Might just be the nature of the exhaust. The plug looks darn near perfect.
But HOLY HELL can she be a #$%* to get started!! I kicked until I thought I was gonna pass out this afternoon.
I have the mixture screw set between 1.5 and 1.75 turns out (TM36-68 pumper carb). I started at 1.75 turns and went out, but that made the idle sluggish. Going in towards 1.5 turns cleaned up the idle and maybe helped with the "chuff, chuff" on decel.
When I installed the stator, I just set it in the center of the slots on the backing plate. Is there such a thing as "setting timing" on the CDI model? Maybe adjusting the stator position would help starting?
I've read where people with new coil, CDI and stator experience 1-2 kick starting. Something is obviously not quite dialed in on mine just yet. What would you check next?
I base lined the carb slide per some instructions member ASE-79 gave me. I did experiment with the idle screw (slide position) and, to be honest, I'm not sure where it is at now. You can't really bottom it out and start over without seeing the slide. But the fact that it idles darn near perfect when running makes me think it's OK.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #328 on: May 20, 2019, 11:48:27 AM »
And since everybody likes pics:
'71 CB500 K0
'81 Yamaha XS650
Offline jgger
« Reply #329 on: May 20, 2019, 12:15:16 PM »
My old 2 stroke diet (DIRT gotta love auto correct!) bike had a magneto ignition similar to what you have. Timing was set with a dial indicator in the plug hole( probably not on a 4 stroke). Then there was a hole in the flywheel and the coil, insert a pin and it aligned everything. Might have a similar step for your set up.
« Last Edit: May 20, 2019, 07:14:16 PM by jgger »
« Reply #330 on: May 20, 2019, 02:53:07 PM »
It's amazing how long that bike has been in production (in various evolutions).
Offline Scott S
« Reply #331 on: May 21, 2019, 07:24:56 AM »
Well, that might have something to do with it.
 Let me get a new plug and see how it acts.
'71 CB500 K0
'81 Yamaha XS650
Offline jgger
« Reply #332 on: May 21, 2019, 08:27:26 AM »
A little super glue and some shrink wrap and you should be good to go. 👍
Offline Fezzler
« Reply #333 on: May 26, 2019, 11:26:36 AM »
Good looking ride.
1975 Honda CB550f in parts in progress
1978 Honda CB550 Four K4
1971 Honda CB500 Four K0
2008 105th Anniversary Edition HD Road King
(Sold) 1998 Honda Shadow ACE Deluxe VT750
1973 Schwinn Stingray (Blue Deluxe - RIP Jack and Rose)
Offline Scott S
« Reply #334 on: June 02, 2019, 04:33:45 AM »
 Just because.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #335 on: June 02, 2019, 04:40:18 AM »
 Took the Glutton out for a ride yesterday. Stopped by the dealership and saw the new Super Cub, Monkey and Grom. I like the Cub, but I could build one for half the price. The Suzuki Van Van was cool. The Kawasaki W800 Cafe was pretty but the seat felt like a brick (they had two vesrions, identical except one was lowered). The new Z900 was nice.
« Last Edit: June 02, 2019, 04:42:48 AM by Scott S »
'71 CB500 K0
'81 Yamaha XS650
« Reply #336 on: June 02, 2019, 06:41:31 PM »
The Z900RS is a great bike, but I bet you got some gawkers out looking at the Glutton!
Offline Scott S
« Reply #337 on: June 03, 2019, 07:44:38 AM »
 Kinda on hold on projects right now so I pulled out this 550 engine for a quick clean up and de-greasing.
 This one is a '78 550K engine, so it has the upgraded rocker cover. It was a freebie, given to me after a friend finished his 550 project. I've had it for a little while now and have been collecting parts for the bike it's going in. Then I got the 550F from CalJ and went to work on that one instead.
 I was gonna just clean it up and tune it up and use it as-is, but then I saw this...
 Two broken exhaust studs and a bad attempt at drilling them out. Luckily, I have a nice, complete '77 head out back. I also have a head gasket, pucks and 7 valve stem seals....doh!
 Ordered ONE valve stem seal from eBay yesterday. I'll clean up the head, lap the valves, install new seals and then just swap the heads. Maybe not easier than paying a shop to repair the stud holes, but certainly cheaper.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #338 on: June 03, 2019, 07:46:33 AM »
 Cleaned up OK, I think. I also have a full set of polished covers that Chewbaca5000 did for me a while back, when he had the members special going on.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #339 on: June 07, 2019, 09:10:05 AM »
 Got the wheels trued and the Avon Roadriders mounted. That allowed me to get the chain on and adjusted, as well as the brakes on both ends.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #340 on: June 07, 2019, 09:12:08 AM »
 I love the way the front end looks. I'm especially proud of the fender/fork brace.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #341 on: June 07, 2019, 09:14:57 AM »
 I also swapped to some lower Super Bike bars, trying to get the wiring harness from the controls to fit where they're supposed to fit.
 And for whatever reason, the muffler hanger/center stand stop I was using is now too close to the swing arm. I think it's because of the taller tires. I have the correct brackets on order from Delkevic (I was attempting to use the stock 550F muffler hanger/stop).
'71 CB500 K0
'81 Yamaha XS650
« Reply #342 on: June 07, 2019, 09:31:54 AM »
I'm digging the street tracker look of this bike.  Are you staying all black on the bodywork or adding any contrast features?
Offline Scott S
« Reply #343 on: June 07, 2019, 09:39:34 AM »
 There will be some contrast features. ;)
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #344 on: June 09, 2019, 08:10:49 AM »
 Got the wiring sorted out today. All that's left is to tidy it up a bit. I can do everything back to the tail light/rear turns. I'll do those once the seat is painted and it's installed for good (the wires for the tail/brake attach to the seat frame.
 I now have spark and all lights work as they should!
 Since the wires on the aftermarket controls were a little short (only on LH control, really), I notched the front of the junction box and ran the wires in from the front instead of the top.
 It all fits and I can go lock to lock on the bars without pulling them too tight or disturbing the connections.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #345 on: June 09, 2019, 01:29:03 PM »
 Pulled out the spare '77 head today to clean it up. I could tell the combustion chambers and valve faces had been cleaned. I was pleasantly surprised to find that the valves had already been cleaned and lapped and valve stem seals had been replaced.
 I put this sucker back together as-is and gave it a coat of paint.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #346 on: June 12, 2019, 10:28:07 AM »
Not gonna lie.... took a big, long break from this project. Had life get in the way over the winter. Had lots of other distractions and, honestly, I just lost interest in it. I sold the Brat project with the stock 550 engine. I even tried to sell the 750 swap project and, I guess you could say luckily, I had no takers.
 So... I took it apart and started working on it again.
 I got the frame, swing arm and various bits and hangers painted yesterday. Today, I adjusted the valves (all were within specs but I snugged up the intakes just a bit) and slotted the timing advance plate to I can try advancing the timing once I get it running.
 I tried to install the starter motor I bought a year ago only to find that I had a -'98 starter and I have a '00 motor. Doh! Got the correct one ordered and once it's installed I'll get the engine back in the frame and start putting this thing back together.
'71 CB500 K0
'81 Yamaha XS650
Offline Fezzler
« Reply #347 on: June 12, 2019, 08:03:20 PM »
What a slacker!  Can't work graveyard shift, moderate forum AND complete 5 project bikes at once!  NOT!
Seriously, you're A+ mentor for garage wrenching and more!
Remind me (photo?), which one was the Brat Project?
(Also, getting ready to put carbs on cb500 project.  Fresh rubber for manifold.  On the cb550 I used the board on the back of carbs method with ratchet strap around board and front of frame and tightened until they popped in.  You have a preferred method?)
Offline Scott S
« Reply #348 on: June 13, 2019, 03:07:43 AM »
 The Brat was the leftover GS550 with the flat seat.
 And no more night shift for me! I left that job and have been on an extended vacation. Start my normal, 8 hour day shift job soon.
 I use some white lithium grease in the manifold rubbers. Loosen the band clamps more than you think they need to be (all 8 of them on the manifolds). Same with the clamps on the two inner air box rubbers.
 Remove the screws that attach the air box to the frame so that it will slide back. I remove the two outer air box boots and install them once the carbs are in the manifolds. They can be pinched and squeezed in. Just line up the tabs on the boots with the dot on the plenum when you get them in there. Put on outer band clamps and tighten up everything.
'71 CB500 K0
'81 Yamaha XS650
Offline Scott S
« Reply #349 on: July 13, 2019, 09:45:18 AM »
 Today was gonna be fire up day for the CB550. That didn't go so well.
 I noticed right off the bat that the carbs were pissing fuel like crazy between the 1 and 2 carb bodies. Figured I'd fill up the bowls and try anyway.
 Cranked and cranked and cranked. It acted like it wanted to start when I went to WOT. Finally caught and ran for just a few seconds, but only on the #3 cylinder.
 I took a look at the timing with a light when I was turning over the engine. Didn't seem to be quite right but it's hard to tell when it's not running properly...or at all. Tried advancing and retarding it a little, just to see if it would help the engine catch and fire. No luck. I'll come back to it once it's running on all four.
 Went ahead and pulled the carbs and dropped them off with Rick at OldSkoolCarbs.
 After I pulled the carbs I noticed that the cam chain tensioner nut/washer was leaking oil. Changed the O-ring and swapped around the crush washer.
 This was supposedly a running engine a few years ago. I did check the valve adjustment, but I'll go through that again and set the cam chain tension again while I'm at it. Then try again when I get the carbs back.
'71 CB500 K0
'81 Yamaha XS650
