Author Topic: CM 400auto  (Read 1915 times)
Offline trebot
  • Like anything New as long as it's Old
CM 400auto
« on: July 16, 2017, 02:05:05 PM »
Looking at '81 CM 400 with auto trans.  Know nothing about Hondamatic.
Does the trans have any issues I should look for?  Any "schooling" would be appreciated.
Offline jukku
  • Happy with my Hondamatic
Re: CM 400auto
« Reply #1 on: July 20, 2017, 08:28:46 AM »
Almost idiot proof! :o
Offline jonnycakes
Re: CM 400auto
« Reply #2 on: July 20, 2017, 04:18:41 PM »
when I was drinking, id leave mine in 2nd and never shift.
'Matic-Fanatic
Offline jweeks
Re: CM 400auto
« Reply #3 on: August 07, 2017, 07:55:21 PM »
No clutch discs to replace so it can stay sealed for a long, long time. Not a lot of power. Same improvements available like for the 4 cylinder versions. Clutch version camshaft advanced a little to replace the little cam it comes with. Power depends on ring seal. You can resleeve the block for larger pistons and more compression. Easy upgrade is using the oversizes from Honda for the 450A. Clutch carbs are bigger if my memory is correct. Cylinder head can't be improved much. One thing that Honda improved when they went to the 450A version was using an external oil line to add oiling to a couple of areas of the camshaft to reduce wear. If you're doing a lot of miles, I recommend an external oil cooler. I'm a fan of the mineral based oils in it. Front springs are weak, especially for 2 up riding. You can get a few different rear shocks, but nothing affordable and significantly better that I've tried. Have fun with it.
