Author Topic: russian atomic poweres ships/u boat are in the esterne sea..hope they not leak..  (Read 1572 times)
Online strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=191e8s9cgsusei4mo88qmccou7&/topic,60973.0.html
going through storebelt passing Langeland last evning...
i hate all this v-w.... vords
Offline vfourfreak
  • Do you think that's wise
Go fishing in your boat (but not too close to them) If you catch fish with three eyes throw them back and get home fast.
Kev
Offline vfourfreak
Yup. Lots of meetings held to promote better understanding and good will. Nothing to fear here.
Kev
« Last Edit: July 22, 2017, 12:50:28 PM by vfourfreak »
So, what's your guess? The sub's radiation emissions more, the same, or less than the fukashima plant in Japan?
« Last Edit: July 22, 2017, 03:30:50 PM by TwoTired »
Offline vfourfreak
Funny they sail U-Boat on the surface, except to make a statement.
Kev
Offline South harbour Honda
They have to be at surface, international shipping lane, but Danish water and max 3 ships or U-boats at a time if your not a NATO member.
Stil have to keep an eye on the ruski.
They are part of Rus/China navy drill in the Baltic sea. first time we see chinese navy in Baltic sea.
Erik
Denmark
« Last Edit: July 23, 2017, 01:27:44 AM by South harbour Honda »
Honda cb 550 - 1974
Online strynboen
its only for show..so ve can see they still can move them(..vitaut tug boat)
..the Eastern sea is mostly used bu spion u boats..not atomic missil carryed ones
..after ve build the great beld brigde.( and small belt have a brigde too).ve can hold them traped inside the Eastern sea.they now ve have a brigde to sveden too..so all shiplanes can be bolkadet..aut of the "østersø"
.the germens have moved all u boats to norvay..and operate from there(since ww2..they aktuly never realy left norvay)..to get aut of the lost zone..
..but all that is history now
the nato defend line goes through skagerak..North of denmark...so all South of this vas lost to the Eastern if var broke aut)
« Last Edit: July 23, 2017, 04:41:23 AM by strynboen »
I would think subs usually run on the surface...cheaper to run that way.
Offline vfourfreak
With subs, stealth is usually the name of the game. Its more dangerous for them on the surface.
Kev
Yeah , I know..     but just moving A to B in peacetime while not on an exercise, they don't do  a to  b.
 No need to stealthy.
Online strynboen
moderne u boats is a lot farster under vater then surfased..and its more relaxing for the crew. to stay down.as most systems is optimised to Work dovn under
..so riding up are just for show and political vork..but 26 meters vide and more in height..its just not possibel to go under vaters..
the Photo is the last Danish u boat..germany build in the1960,,..its a sinkel skin type..26 mm at the thinnest at the top side of the tube..and 55 mm at the keel..ve had to cut it in half to transport it..and veld it together ..so it still looks and feels like a boat to visit..just hate those hackers vho cut Things in thin pieces to make easy entre for public..roling thairs have never been for u boat ..
Offline vfourfreak
Is that the "Sælen" ex Norwegian navy ?
Kev
Online strynboen
no sistership" springeren" also ex norvay..build in germany..denmark bayed 2 or 3 back in the 1980..i think it vas ..one sank once in docking..after they took the batteryes aut..and thorth it still vas stabil..but no...the other sank under transport..they forget to close the hatch...so denmark never got any good use of them. there vas build inn a Flex snorkel and some ekstra room .one vas in the dessert storm??????..but the main engine blow up..so no luck there either...crazy stuff to send a Cold vater u boot to topic vaters...cooling systems vas not gearet to Work there
Those that design them and build them are not around during operation and not having many subs it cluld be understood how their depth of knowledge is small and they are unaware of its limitations or design limitations.
Most of the time when deployed the US subs are submerged after sailing out into open sea.  They rarely surface except when in port.  Not uncommon to be months underwater.
Online strynboen
funny thing..the floth dock the u boat  sank in..is the same as i visited for2 weeks ago..at  mine sail trip to Marstal..here is some photoes..so it have been used as a u boat dock in denmark..after/since.. ve got it in 1945 in germany..and in this days it are get buksered/moved to Svendborg toa bigger shipyard..so ve are loosing it here local..but it are still vorking be used since 1936..amd most hardvare is still the same..pumps are simens 1000 volt engines
« Last Edit: July 24, 2017, 12:47:40 PM by strynboen »
Offline eigenvector
Nope - as soon as they have the opportunity they slip underwater and stay there until their deployment is over.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
