Author Topic: 1990 Ducati 750 Sport build  (Read 19331 times)
Offline brandEn
Re: 1990 Ducati 750 Sport build
« Reply #25 on: August 04, 2017, 01:35:28 PM »
Tank looks great Larry!
Offline tweakin
  • tear down
« Reply #26 on: August 04, 2017, 04:58:18 PM »
+1, great work as usual Larry!
Offline tweakin
  • tear down
« Reply #27 on: August 26, 2017, 08:24:39 PM »
Engine is ready to go.
Offline tweakin
  • tear down
« Reply #28 on: August 26, 2017, 08:26:13 PM »
Finished the mock up and dropped all my hard parts off at my powdercoater.  Rebuilt the 40mm front brakes and waiting on the rebuild kit for the 900ss rear brake.  Also freshend up the front discs and ordered a bunch of parts.
Offline calj737
  • I refuse...
« Reply #29 on: August 27, 2017, 05:09:57 AM »
Please go ahead and crate that up and ship it off to me, Tweakin'. I'll pm my address to you for your convenience  ;)
Offline innovativems
    • Innovative MotoSports
« Reply #30 on: August 27, 2017, 05:58:38 AM »
I'm loving this build!   One of these days I want to build a 900ss
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #31 on: August 27, 2017, 07:59:43 AM »
Mind is we ask what was done to the motor?  Looks fantastic, was it just cosmetic?
Offline tweakin
  • tear down
« Reply #32 on: August 27, 2017, 08:29:51 AM »
The motor only had 8000 original miles on it and I know the original owner.  Once I was able to fire up again I decided to not split the cases.  Compression was checked, new belts and pulley bearings and back covers, valves properly adjusted, new clutch and clutch slave rebuild and the rest was cosmetic.
« Reply #33 on: August 27, 2017, 11:49:42 AM »
I always look forward to one of your projects, Tige.  Personally, I hate to see the stock red and silver graphics go away, but your visions are usually right on the mark.  I'm sure it will be an awesome bike now that it's in your hands.
Larry, that is some phenomenal touch up work!  Mad skills.  But, everyone who has seen and  appreciates your work... we knew that already.
While simple, I wonder if anyone has flipped the colors on Ducati and use white where it was once red and red for the Ducati logo.  It would be a stark contrast...no clue how it would look.  I will be interested to see Tighe's vision.
Good luck guys!
Idaho is beautiful, from the photos I have seen.
If you are into slope soaring RC gliders they have some fantastic places to fly. I find it to be a fun hobby, combining the peacefulness of gliding and working thermals and the wind with the ability to do some aerobatics when you want as well as high speed passes and pumps; diving and pulling up to soar higher and higher with the energy you build from the dives, a repeated U shaped flight path.
Tighe, as always you have mad skills cleaning up and working on bikes.
David
« Reply #34 on: August 27, 2017, 06:09:17 PM »
Tige,
This is another jewel.
How did you clean up the rotors? Did you re-annodize them? They look pretty fresh.
Offline tweakin
  • tear down
« Reply #35 on: August 27, 2017, 07:54:50 PM »
Tige,
The rotors were freshened up with VHT 729 caliper paint.  I am on the look out for some nice snowflake or even better would be full floating discs but will use these until I find a decent set.
« Last Edit: August 27, 2017, 08:10:59 PM by tweakin »
« Reply #36 on: August 27, 2017, 09:09:10 PM »
Tige,
I had a good set of snowflakes but I cannot find them.
Offline brandEn
« Reply #37 on: August 28, 2017, 10:58:36 AM »
Can't wait to see this one complete
Offline palepainter
    • Mike Learn custom paint and airbrush.
« Reply #38 on: September 02, 2017, 06:05:28 PM »
Loving this.  So good to see the progress and details.
Offline nvr2old
« Reply #39 on: September 04, 2017, 10:47:18 AM »
Tige, your attention to detail is just such a treat to watch unfold.  That engine looks better then it did when it was brand new.  I admire your high standards.  More, more, please...
Hey, David..funny you should mention slope soaring RC planes.  A friend of mine and I did that for years.  Beautiful area to do it.  Loved the serenity, quiet aspect of it, and the focus it required to keep those birds aloft.  A very unique hobby.  Haven't done it for several years now and miss it.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
« Reply #40 on: September 06, 2017, 02:43:44 AM »
Tige, sorry to have misspelled your name as Tighe...
Do you take an abrasive wheel, 3M, like used for rust repair to strip any build up on the discs or just sand them a bit with a sanding block to strip any resin/brake pad residue or build-up?  If you had a Lathe it would be easy and very quick to do with a sanding block and slow speed...taking longer to chuck them up in something to hold them in the lathe than to give them a clean surface.
Do you bake the VHT after paint?  I found the VHT caliper paint will chip easily unless ran through the oven for curing...and I inevitable chip it and have to rework it if I am not careful with it before heat curing...so getting a batch to be efficient with the oven I have to be careful with painted stuff.  I have had that issue with aluminum bodied calipers...
Larry, should I direct you to a few Idaho slope fliers on RCGroups?  It is peaceful doing alone but a lot of fun with others and some "gentle friendly" slope combat with EPP flying wings can be a ball of fun.  Much harder to have a mid-air or even tag someone with another plane when they are trying to avoid you...
There is even an Idaho slope competition/get together that is significant in # of pilots s well as drawing pilots from states away.
Offline tweakin
  • tear down
« Reply #41 on: September 06, 2017, 08:41:05 PM »
Another small step forward on this build.  Powdercoating is finished so I can begin to reassemble.  Also picked up an adjustable front end and full floating front rotors.
Offline tweakin
  • tear down
« Reply #42 on: September 09, 2017, 11:30:53 AM »
Got her into a roller.
Offline tweakin
  • tear down
« Reply #43 on: September 09, 2017, 04:10:30 PM »
Before paint mock up.
« Reply #44 on: September 10, 2017, 11:56:37 AM »
I like the swingarm change-over to black.  It flows nicely with the motor and makes the trellis frame pop more.
Offline tweakin
  • tear down
« Reply #45 on: September 12, 2017, 07:01:03 AM »
I went back and forth on what to do with the swingarm.  Really happy with hoe it turned out and agree it makes the frame pop nicely.
Hope to finish wiring her up this weekend but wont be able to fire her up until the slip ons arrive from Italy, ordered them over a month ago and still waiting.  I was able to get the headers ceramic coated while waiting.
« Reply #46 on: September 13, 2017, 01:17:45 PM »
We really are lucky with the parts networks that we have for Japanese bikes.  My buddy is waiting 3 weeks for a seat for a 2015 MV Agusta.
Offline brandEn
« Reply #47 on: September 13, 2017, 04:39:34 PM »
Looks good! Did you just hack up the stock seat and fairing? I really like the flow. Gonna look awesome painted up.
Offline tweakin
  • tear down
« Reply #48 on: September 13, 2017, 07:25:42 PM »
Yes building this after Honda builds is a completely new experience.  I actually love it!  Searching all over for parts in a strange way has been really fun.
Offline tweakin
  • tear down
« Reply #49 on: September 13, 2017, 07:31:38 PM »
Hack?  C'mon man. 😀   I trimmed the tail section a bit and that was it.  I want to bike to look period correct (90's) with a bit of modern flare.  If it was a more sought after Duc I would have ordered repop fiberglass to cut.
All the racetech goodies should be here this weekend to upgrade the suspension and paint should be done in two weeks.
Hope to get in a few test rides before the rainy season comes back.
